how to read ky40 mechanical encoder ?
Results 1 to 21 of 21
    Jun 2008
    Varese , Italy
    Default how to read ky40 mechanical encoder ?
    Good day to all of you in this forum.
    I used an optical encoder in the past with pbp and I had good result.
    Now I have a mechanical encoder similar to the ky40 or ky-040 that is widely available on the net.
    I am not able to make it working correctly and still having bad results.
    I did filtered the A and B signals with two 0.1uf and 10k resistors pull_up: no solution up to now.
    Any help on the this matter please ? Or any sample code available ?
    Ambrogio
    Default Re: how to read ky40 mechanical encoder ?
    Is your encoder like this ?
    http://www.ebay.com/itm/400964660325...%3AMEBIDX%3AIT
    These encoders are (supposedly) destroyed by pullup resistors.
    Or is your encoder just a noisey old mechanical switch type?
    Comparators are supposed to be good buffers for mech switches.
    OK I found my answer, Mech. as stated in your post
    You are needing to "debounce" these.
    Jun 2008
    Varese , Italy
    this is my ecoder:
    http://www.ebay.com/itm/1PCS-KY-040-...item27e8f12b89
    Any help , please ?
    Ambrogio
    CAUTION: UNTESTED CODE
    A var portb.6
    B var portb.7
    state var byte
    if(( A == 1)&&(B==1)) then state = 1
    if(( A == 1)&&(B==0)) then state = 2
    if(( A == 0)&&(B==1)) then state = 3
    if(( A == 0)&&(B==0)) then state = 4
    ;pause 100
    if state = 1 then portC = %00000001
    if state = 2 then portc = %00000010
    if state = 3 then portc = %00000100
    if state = 4 then portc = %00001000
    debug "  state = ",#state
    I found this interesting.
    http://makeatronics.blogspot.it/2013...ture-with.html
    is your "re " a 20 count per turn with indents ? the 10 for a $1 ones I got from ebay have enough contact bounce to start a spring factory but the inherent software filtering of the above code does an amazing job on them 1 (4k7 pu r's and .1uFs included). I have not ported this to pbp but have for mikro c and xc8 if that helps
    http://www.circuitsathome.com/mcu/re...age-1#comments
    this link has some other insights
    basically you just need to adjust your re count using this current value / old value matrix (illegal values [bounces] are just ignored )
    Sep 2009
    One of possible ways to implement filter(Not tested)
    OutputValue=0
    Select Case OldValue
    Case 0
    If Current=1 then OutputValue=-1
    If Current=2 then OutputValue=1
    Case 1
    If Current=3 then OutputValue=-1
    If Current=0 then OutputValue=1
    Case 2
    If Current=0 then OutputValue=-1
    If Current=3 then OutputValue=1
    Case 3
    If Current=2 then OutputValue=-1
    If Current=1 then OutputValue=1
    EndSelect
    Jun 2008
    Varese , Italy
    still not able to make my panel encoder working .
    Could someone post the complete code applicable to mechanical encoder like my one please ?
    Thanks in advance.
    regards,
    Ambro
  1. Question about mechanical relay
    Last Post: - 1st October 2012, 11:37
  2. Mechanical question
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 11th October 2011, 06:41
  3. Probe to read quadrature encoder with DT_INT need help
    By phoenix_1 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 21:43
  4. Mechanical question
    By selbstdual in forum Off Topic
    Last Post: - 8th February 2008, 15:34
  5. Replies: 6
    Last Post: - 14th October 2005, 20:41
