Getting 19200 baud serial out of a PIC
Results 1 to 16 of 16
    Sep 2008
    Maine, USA
    Default Re: Getting 19200 baud serial out of a PIC
    Thanks Dave,
    I dropped in a 10MHz crystal oscillator and YES that works. But not the 4 MHz internal osc apparently.
    Unfortunately a resonator will eat up 2 valuable pins, and a crystal oscillator (using 1 pin) is too pricey for the project. So I'll have to bump up to a 16F627 or something, and that is $$ too. Argh!
    "Do or do not, there is no try" Yoda
    Dec 2005
    Quote Originally Posted by tekart View Post
    The 12F615 cost 2/3 what the 12F675 costs and has a 4/8MHz internal oscillator. I've used it at 9600 but have never had the need to try 19200. It's a fairly new chip so the accuracy of the internal oscillator may be better than that of older PICs.
    Sep 2008
    Maine, USA
    Thanks Dave,
    I'll consider that F615 chip. It has the 10 bit A/D that I need too. I can sacrifice the OSC1 pin and justify the cost of an external crystal oscillator I think. It's all coming together now.
    Thanks all.
    PIC12F1822
    8 Pins
    Internal precision 32Mhz oscillator.
    EUSART (HSEROUT).
    You can run at 250K baud on the internal OSC.
    Requires PBP 2.60A.
    Dec 2005
    8 Pins
    EUSART (HSEROUT).
    Can the EUSART be inverted? If not, it may require additional hardware, depending on the application.
    The transmit side can be inverted.
    But with a 32Mhz OSC, 19200 is no problem for SEROUT2.
    The bluetooth module may take true levels though.
    Sep 2008
    Maine, USA
    That's a really cool chip - but it is pricey. I'm still on PBpro 2.50 - time to upgrade I guess. But I will try out the 12F615 first, I'm getting some next week. My bluetooth (BTM-182) unit needs true serial so that is OK.
    Thanks Darrell - you da man!
