Getting 19200 baud serial out of a PIC
Results 1 to 16 of 16
    Default Re: Getting 19200 baud serial out of a PIC
    Some of the older chips do not have a very accurate internal OSC, I can not say about the 675. If this is for production it might be worth using a 50 cent resonator just to be sure.
    Sep 2008
    Maine, USA
    Thanks Dave,
    I dropped in a 10MHz crystal oscillator and YES that works. But not the 4 MHz internal osc apparently.
    Unfortunately a resonator will eat up 2 valuable pins, and a crystal oscillator (using 1 pin) is too pricey for the project. So I'll have to bump up to a 16F627 or something, and that is $$ too. Argh!
    "Do or do not, there is no try" Yoda
    Dec 2005
    Quote Originally Posted by tekart View Post
    The 12F615 cost 2/3 what the 12F675 costs and has a 4/8MHz internal oscillator. I've used it at 9600 but have never had the need to try 19200. It's a fairly new chip so the accuracy of the internal oscillator may be better than that of older PICs.
    Sep 2008
    Maine, USA
    Thanks Dave,
    I'll consider that F615 chip. It has the 10 bit A/D that I need too. I can sacrifice the OSC1 pin and justify the cost of an external crystal oscillator I think. It's all coming together now.
    Thanks all.
    PIC12F1822
    8 Pins
    Internal precision 32Mhz oscillator.
    EUSART (HSEROUT).
    You can run at 250K baud on the internal OSC.
    Requires PBP 2.60A.
    Dec 2005
    8 Pins
    EUSART (HSEROUT).
    Can the EUSART be inverted? If not, it may require additional hardware, depending on the application.
    The transmit side can be inverted.
    But with a 32Mhz OSC, 19200 is no problem for SEROUT2.
    The bluetooth module may take true levels though.
    Default 19200 and clock accuracy
    I make data loggers using the 18F4620 running on internal clock (INTIO2) and a Dallas DS1629 with a 32768 Xtal as RTC and temperature sensor. I do a clock accuracy check by instructing the DS1629 to output a clock at one quarter rate and count transitions. See attached code.
    In over 100 loggers the PIC18F4620 clock accuracy has always been better than 0.1% (1000 ppm) and much smaller than the minimum increment obtainable by changing the OSCTUNE register so I have never had to apply a speed correction.
    I get excellent data with DEBUG at 19,200 bps BUT I ALWAYS use CharPacing 100 to give some extra stop bit time. This functions flawlesly for me.
    HTH
    Brian
    TuneOscillator:
         high pgc : pause 2 : debug 13,10,"Comparing IntOsc with RTC ", 13, 10
         i2cwrite SDA, SCl, %10011110, $AC, [ %10000101]
             'OscOut = OscIn/4, temperature on demand
         pause 20
     'StartConversion:
         i2cwrite SDA, SCl,%10011110, [ %11101110]       ' send $EE
          'activate DS1629 OscOut to divide by 4.
          'make a copy of the OSCTUNE register before any changes
          '32768 Hz/4 = 8192 Hz.  A 2 second window should see 16384 counts.
          'NOTE.  Either leave this function active in live logger OR allow
          'conversion time for the DS1629 to fetch tenperature.
          count clkpin, 2000, clkcal  'returns number of low to high transitions
          debug 13, 10, "ClkCal = ", #clkcal  'in a 2 second window
          if clkcal > 16384 then 'Clock is SLOW
             debug ", SLOW by ", #(clkcal - 16384)
             debug ", FAST by ", #(16384 - clkcal)
          debug , " ticks in 16384. "
          clkerror = abs((1000000*(clkcal - 16384))/16384)
          debug  "Clock error = ", dec clkerror, " ppm", 13, 10
          i2cwrite SDA, SCl, %10011110, $AC, [ %00000101]  'Turn OscOut OFF
