PBP projects for R/C models
Results 1 to 40 of 772
    May 2010
    Default Help Servo controller
    Hello friends! Could someone please tell me how to do the PicBasic control two servo motors at the same time, a 100 by sending a pulse and another 50 using PIC16F628A
    Quote Originally Posted by Magoga View Post
    How about up to 9 servos? http://www.picbasic.co.uk/forum/cont...th-2-I-O-lines
    http://www.scalerobotics.com
    Nov 2009
    Fitchburg, Mass
    Smile I'm on TV!
    Folks, I had an opportunity to show off my robocars on Fitchburg Access Television. I am in the second half of the show. If you like skip the first twenty three minutes twenty seconds.
    http://prometheus.fatv.org/media/127...tchburg_10511/
    Nov 2009
    Fitchburg, Mass
    Wink function calls....
    Folks,
    I have some grande ideas to improve the robotics of my robocars. Trouble is I need what in C are called functions.
    Any hope in PICBASIC PRO for my 16F887? You all got any suggestions? My guess is that In order to translate my PICBASIC code to C I will need to learn PIC Assembly so that I can better understand what is really happening.
    Has anyone done this? Did he/she create a mid-range PIC set of C libraries?
    Ken
    May 2007
    While any C compiler does certainly support functions, there are at least 3 dialects of BASIC for PICs that not only support functions but features such parameter passing, global/local variables, etc. that allow structured programming.
    Nov 2009
    Fitchburg, Mass
    Default I should be more clear
    The code in my little cars is, in fact, very little. It only deals with distance. It does not calculate rates of speed, of approach, of turn. It does not calculate angles. It does no mapping.
    Maybe my 16F887 based kit is not up to that task. I am not sure and I do not know how to find out. Maybe I could architect better in C, but it has been literally twenty five years since..... and I used to have a very extensive (corporate supplied) library.
    Suggestions?
    Ken
    May 2007
    mbed is a tool for Rapid Prototyping with Microcontrollers mBed
    Microcontrollers are getting cheaper, more powerful and more flexible, but there remains a barrier to a host of new applications; someone has to build the first prototype! With mbed, we've focused on getting you there as quickly as possible.
    Huge library (check out the Handbook, Cookbook and Code pages), free IDE and C compiler. 100MHz 32-bit MCU, 512kB Flash, 64kB RAM.
    Suggestions?
    Ken
    Hello Ken.
    Sure, there are more powerful chips to use. There are also more powerful languages. But, the question is, what are you going to be doing, and do you really need to change chips, and or languages? So far, the use you have made the chip perform, is probably the equivalent of an old man walking with a walker. You have not taxed your current environment whatsoever! Sure, a lot more could be done, but I think, if it was done right, the most required might be an 18F device.
    Currently, your PIC18F887 can handle 5 million assembly instructions per second. Your hardware (servo) can handle at maximum, 50 instructions per second (pulse width control at 50 hertz, or 20ms frames). So, with every chance to change your direction, your program can perform 100,000 assembly instructions. A lot of PBP code can fit into 100,000 instructions. That can basically go through every available code location (14k program space) on the chip seven times, during the 20ms it has to make a decision.
    Seeing as you are hardly putting a dent in the 14k, shouldn't you at least try to do something more, before saying you don't think the chip can handle it?
    Let's take a look at the items you mention:
    Speed : This is relatively easy to do and will hardly take any code. Put a sensor on a wheel and away you go!
    Approach of turn: You have all the distances measured, why not use them to in your control for turning. Calculate at what point in time will you be x length to the wall, and at this time turn, instead of saying "if my measurement is less than 4 feet, etc etc. Since you are only taking front measurements every 60ms?? or so, you might well be beyond the 4 feet by the time you measure.
    Calculate angles: Cool idea. But with what sensors are you going to determine that? And how? PBP has SIN, COS, Hypotenuse and ATAN built in. Sure these are rough calculations, but I don't know that with your current sensors you will need (or be able to use) anything more advanced. Add a magnetometer http://www.sparkfun.com/products/9371 , and perhaps this could get more complex. If it does need to be more precise, there is a PBP compatible CORDIC include file to calculate SIN, COS, ATAN, Hypotenuse. See http://www.picbasic.co.uk/forum/showthread.php?t=10528 . On an 18F, you can do this 9,000 times per second while still using PBP in our program.
    As for mapping, with your current set up, I would go out on a limb, and say that is impossible with any language. To map, you need to know where you are. You will need more sensors! A GPS (and a large outdoor "track"), or magnetometer, or light sensors that find at least a reference beacon, or barcode like strips on the floor, just to figure out where it is. Lots of ways to do it, some better than others.
    So, from what you have vaguely mentioned, I see no barrier using your current chip, or using PBP. Can you be more specific about what function libraries you are talking about? What ever language you choose, you are going to have to decide how you are going to perform these functions, and what sensors you are going to use to do them.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
