Checking Bit of a Byte using another variable
Results 1 to 8 of 8
Threaded View
  1. #4
    Check.0[Days] tells PBP to treat Check as a bit array with Days as the bit index pointer.
    Since Check is a byte PBP will treat it as an 8-bit array. The lowest bit will be 0, and the
    highest bit will be 7.
    If Days = 5; then IF Check.0[Days]=1 will be testing bit position 6 in Check if you're
    counting bit positions in Check from left-to-right as 87654321.
    Then you would use; IF Check.0[Days-1]=1 THEN.
    If you're counting bit positions in Check from left-to-right as 76543210 then it would work
    with; IF Check.0[Days]=1 THEN.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
