Checking Bit of a Byte using another variable
Results 1 to 8 of 8
    Default Checking Bit of a Byte using another variable
    If I have two byte variables Check and Days.
    If Days only range from 1 to 7, can we check bits in Check based on Days?
    For example, lets say if Days=5, I am having trouble with the following method:
    if Check[Days]=1 then goto whatever
    In the above example I want to check bit 5 of Check variable.
    Is there any other method to do the above task?
    ___________________
    WHY things get boring when they work just fine?
    May 2008
    Italy
    Yes:
    if Check.0[Days]=1 then goto whatever
    Cheers
    Al.
    Quote Originally Posted by aratti View Post
    Al.
    Thanks Al, can you please explain what does "0" in Check.0 does?
    ___________________
    Check.0[Days] tells PBP to treat Check as a bit array with Days as the bit index pointer.
    Since Check is a byte PBP will treat it as an 8-bit array. The lowest bit will be 0, and the
    highest bit will be 7.
    If Days = 5; then IF Check.0[Days]=1 will be testing bit position 6 in Check if you're
    counting bit positions in Check from left-to-right as 87654321.
    Then you would use; IF Check.0[Days-1]=1 THEN.
    If you're counting bit positions in Check from left-to-right as 76543210 then it would work
    with; IF Check.0[Days]=1 THEN.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default little confused
    Thanks for the explanation, few clarifications:
    1) Do bits get counted from right to left OR left to right?
    I mean to say isn't that Check.0[Days]=1 should check bit 4? (Assuming Days=5)
    2) What can I do if Check is a word and I want to check:
    a) Bit 15 & Bit 3 (Just want to know)
    b) Lower byte value & higher byte value
    ___________________
    -Bruce
    tech at rentron.com
    Thanks Bruce, the topics have really been helpful.
    After reading them, I still have one question (Just want to confirm)
    Please correct me if I am wrong :
    Check=[bit7,bit6,bit5,bit4,bit3,bit2,bit1,bit0]
    To access bit7 of Check variable (byte) : Should it be
    Check.0[days] ; Days =7 in this example
    Similarly :
    To access bit1 of Check variable (byte) : Should it be
    Check.0[days] ; Days =1 in this example
    ___________________
