Int Interrupt question
Results 1 to 13 of 13
    Sep 2006
    eee ook, you mean something like:
    RBO = 1 ' call interrupt
    myInterrupt:
    Gosub Display_menu
    @int interrupt
    Display_menu:
    'display result on LCD....
    WIll the return go back to the interrupt or back to where interrupt has left the main program ??
    K
    Sep 2006
    Here is exactly what I need.. I think
    The programs records a multitude of time from an external timer.
    When the user push Pushes Button-A (RB0), it will go to a menu where the user can see all the times. The user can push Again button-A, to see the next time, Pushes again for the following time until it reaches the end. If the Button-A is not press for 10 seconds, the menu exit and return to where it left off. Is this Clear ?? sometime it is clear to me but not to others
    K
    Quote Originally Posted by lerameur View Post
    K
    Hi Ken,
    not exactly, when RB0 does = 1 it sets a flag bit and that bit stays set even if RB0 goes back to zero, your program does something of your choosing as a result and then it clears that flag bit before it resumes, assuming you write the code properly.
    It returns to the next line normally.
    Sep 2006
    not sure I am following you on this one !
    anyone has a written example of an external interrupt program ??
    K
    REGISTER 2-3: INTCON: INTERRUPT CONTROL REGISTER (ADDRESS 0Bh, 8Bh, 10Bh, 18Bh)
    Note: Interrupt flag bits get set when an interrupt
    condition occurs, regardless of the state of
    its corresponding enable bit or the global
    enable bit, GIE (INTCON<7>). User
    software should ensure the appropriate
    interrupt flag bits are clear prior to
    enabling an interrupt.
    R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-x
    GIE PEIE TMR0IE INT0IE RBIE TMR0IF INT0IF RBIF
    bit 7 bit 0
    bit 7 GIE: Global Interrupt Enable bit
    1 = Enables all unmasked interrupts
    0 = Disables all interrupts
    bit 6 PEIE: Peripheral Interrupt Enable bit
    1 = Enables all unmasked peripheral interrupts
    0 = Disables all peripheral interrupts
    bit 5 TMR0IE: TMR0 Overflow Interrupt Enable bit
    1 = Enables the TMR0 interrupt
    0 = Disables the TMR0 interrupt
    bit 4 INT0IE: RB0/INT External Interrupt Enable bit
    1 = Enables the RB0/INT external interrupt
    0 = Disables the RB0/INT external interrupt
    bit 3 RBIE: RB Port Change Interrupt Enable bit
    1 = Enables the RB port change interrupt
    0 = Disables the RB port change interrupt
    bit 2 TMR0IF: TMR0 Overflow Interrupt Flag bit
    1 = TMR0 register has overflowed (must be cleared in software)
    0 = TMR0 register did not overflow
    bit 1 INT0IF: RB0/INT External Interrupt Flag bit
    1 = The RB0/INT external interrupt occurred (must be cleared in software)
    0 = The RB0/INT external interrupt did not occur
    bit 0 RBIF: RB Port Change Interrupt Flag bit
    A mismatch condition will continue to set flag bit RBIF. Reading PORTB will end the mismatch
    condition and allow flag bit RBIF to be cleared.
    1 = At least one of the RB7:RB4 pins changed state (must be cleared in software)
    0 = None of the RB7:RB4 pins have changed state
    Bit 1 of the intcon register is what your interrupt routine will be looking for, Assembly interrupts will act on it immediatly (Like Darrel's) PBP interrupts will get to it eventually.
    Sep 2006
    I read the definition in the manual, I meant of a small example program .BAS
    I will give me a more hands on view thanks
    Here are some snippets from a 16F873A project.
    It triggers on PORTB.0 using ON INTERRUPT.
    ON INTERRUPT GOTO MYINT
    INTCON = %10010000
    MAIN:
    'DO STUFF
    GOTO MAIN
    DISABLE
    MYINT:
    IF PORTB.0 = 1 THEN
        PC = PC + 1
    	WRITE 3,PC.BYTE0
    	WRITE 4,PC.BYTE1
        READ 3,PCNT.BYTE0
    	READ 4,PCNT.BYTE1
    	PC = PC
    INTCON.1 = 0
    RESUME
    ENABLE
    Hi Ken,
    Spend an hour or more in ME Labs website, there are a Gaggle of sample programs and user submitted programs there. It is a very good resource, I promise. It may / not have the example you seek, it IS worth the time.
    http://melabs.com/resources/samples-pbp-general.htm
