You were getting close, but it did need a bit more.
The pins I used are probably different than yours.
INCLUDE "ModeDefs.bas"
INCLUDE "AllDigital.pbp"
datapin    VAR PORTB.1
clockpin   VAR PORTB.0
latchpin   VAR PORTB.2
led        VAR PORTA.5
Tosend     VAR BYTE
char       VAR BYTE
RS_state   VAR BIT
GOSUB InitLCD
main:      ' 74HC595 : 5=6(E), 4=4(RS), 3=14(DB7), 2=13(DB6), 1=12(DB5), 0=11(DB4)
    for char = 32 to 90
        gosub SendData
        toggle led
    next char
;----[Initialize LCD]----------------------------------------------------------
InitLCD:
    RS_state = 0
    char = $30
    GOSUB sendHalfnibble
    PAUSE 6
    PAUSE 1
    PAUSE 1
    char = $20               ; Start 4-bit mode
    char = $28               ; Function Set, 4-bit, 2-line, 5x7
    GOSUB SendCommand
    char = $0C               ; Display ON
    GOSUB SendCommand
    char = $01               ; Clear Screen
    GOSUB SendCommand
    char = $06               ; Entry Mode
    GOSUB SendCommand
;----[Send the Upper nibble to the LCD]----------------------------------------
sendHalfnibble:
    Tosend = char >> 4  ' High Nibble only, needed for the initialisation routine, move Char 4 bits to the right
    GOTO sendtolcd
SendCommand:
    RS_state = 0
    GOSUB ToLCD
    PAUSE 2
SendData:
    RS_state = 1
ToLCD:
    Tosend = char >> 4                           ' High Nibble, move Char 4 digits to the right
    gosub sendtolcd
    tosend = char & $0F                               ' Low nibble = char, the other bit's won't matter
    gosub sendtolcd
SendToLCD:
    tosend.4 = RS_state                         ' RS state setzen "0" = command für LCD, "1" = Zeichen an LCD
    tosend.5 = 0                                ' Enable Bit OFF
    shiftout datapin,clockpin,msbfirst,[tosend]   ' send data to HC595
    high latchpin                               ' write into paralell buffer
    low latchpin
    tosend.5 = 1                                ' enable bit ON
    shiftout datapin,clockpin,msbfirst,[tosend]   ' data to HC595
    high latchpin                               ' sent to paralell buffer
    low latchpin
    tosend.5 = 0                                ' Enable OFF
    high latchpin                               ' write to paralell
    low latchpin
    pauseus 50
