LCD via 74HC595
Results 1 to 8 of 8
Thread: LCD via 74HC595
    Feb 2008
    Default LCD via 74HC595
    Hello coders,
    I'm stuck in a problem: I've connected a LC display with a 16F876A via a 74HC595 stack IC. But the display does'nt do what I want it to.
    The cirquit is O.K., the communication to the stack works fine. And the communication to the display works also fine.
    If I try to send the regular initialisation sequence, like there are code examples all over the net, it won't work. So what I did was sending a incrementing byte starting at zero. Code is something like this:
    RS_state = 0
    main:      ' 74HC595 : 5=6(E), 4=4(RS), 3=14(DB7), 2=13(DB6), 1=12(DB5), 0=11(DB4)
    for char = 0 to 255
    gosub tolcd
    'pause 500
    toggle led
    next
    ' shiftout datapin,clockpin,msbfirst,[var1, var2]   ' MSBFIRST = 1
    sendHalfnibble:
    Tosend = char >> 4                          ' High Nibble only, needed for the initialisation routine, move Char 4 bits to the right
    gosub sendtolcd
    ToLCD:
    Tosend = char >> 4                           ' High Nibble, move Char 4 digits to the right
    gosub sendtolcd
    tosend = char                                ' Low nibble = char, the other bit's won't matter
    gosub sendtolcd
    SendToLCD:
    tosend.4 = RS_state                         ' RS state setzen "0" = command für LCD, "1" = Zeichen an LCD
    tosend.5 = 0                                ' Enable Bit OFF
    shiftout datapin,clockpin,msbfirst,[tosend]   ' send data to HC595
    high latchpin                               ' write into paralell buffer
    low latchpin
    'pause 250
    tosend.5 = 1                                ' enable bit ON
    shiftout datapin,clockpin,msbfirst,[tosend]   ' data to HC595
    high latchpin                               ' sent to paralell buffer
    low latchpin
    'pause 250
    tosend.5 = 0                                ' Enable OFF
    high latchpin                               ' write to paralell
    low latchpin
    As you see, the RS pin is always low, wich means there are only commands to the LCD.
    What happens with this code is, that the LCD cursor is switching on and off, and moving around at some bytes, wich makes me sure that the cirquit works, but I don't know how to send the high and low nibbles correctly. Everything works, but I don't know why or how, wich gives me a headache.
    The stack is connected like: Porta.0 -> clck, Porta.1 -> data, Porta.2 -> latch
    porta.3 at the PIC is a LED for debug blinking stuff (to check if the code is still running)
    the LCD is connected to the stack like described in the code example (first line)
    I've connected a LED to every PIN of the LCD, so with some pauses I can see clearly the data sent to the LCD. This data seems to be O.K. too.
    Well so much for that. Now my questions:
    A byte within the PIC is bitwise like that: 76543210 wich means bit 7 is the first one, bit zero the last one. What about the nibbles? Are the bits 7654 the high nibble, or bits 3210?
    Is it neccesary to send the data first with enable OFF, then with enable ON, then again with enable OFF?
    THX for help, and pls excuse my bad english,
    helloo
    You were getting close, but it did need a bit more.
    The pins I used are probably different than yours.
    INCLUDE "ModeDefs.bas"
    INCLUDE "AllDigital.pbp"
    datapin    VAR PORTB.1
    clockpin   VAR PORTB.0
    latchpin   VAR PORTB.2
    led        VAR PORTA.5
    Tosend     VAR BYTE
    char       VAR BYTE
    RS_state   VAR BIT
    GOSUB InitLCD
        for char = 32 to 90
            gosub SendData
            toggle led
        next char
    ;----[Initialize LCD]----------------------------------------------------------
    InitLCD:
        RS_state = 0
        char = $30
        GOSUB sendHalfnibble
        PAUSE 6
        PAUSE 1
        PAUSE 1
        char = $20               ; Start 4-bit mode
        char = $28               ; Function Set, 4-bit, 2-line, 5x7
        GOSUB SendCommand
        char = $0C               ; Display ON
        GOSUB SendCommand
        char = $01               ; Clear Screen
        GOSUB SendCommand
        char = $06               ; Entry Mode
        GOSUB SendCommand
    ;----[Send the Upper nibble to the LCD]----------------------------------------
    sendHalfnibble:
        GOTO sendtolcd
    SendCommand:
        RS_state = 0
        GOSUB ToLCD
        PAUSE 2
    SendData:
        RS_state = 1
    ToLCD:
        gosub sendtolcd
        tosend = char & $0F                               ' Low nibble = char, the other bit's won't matter
        gosub sendtolcd
    SendToLCD:
        low latchpin
        low latchpin
        low latchpin
        pauseus 50
    Feb 2008
    Hi Darryl,
    thank you for trying to help, but after another three days of trying, changing bytes, switching bits, I am pretty sure that my LCD doesnt meet HD44780 specs for 100%.
    Your code does exact the same as mine did before.
    So I managed somehow to print out some chars, wich makes me sure:
    1. the LCD switches to 4 bit mode
    2. the wiring is right
    but I could'nt use the 2nd line, nor some other commands.
    the next thing I tried was to connect the LC display directly to the pic without the stack - just the same.
    and then I tried to write stuff with the LCDOUT command - nothing.
    Now I ordered some other LCD's wich are used by other people before (LCD1602). Next week I'll see what happenes.
    Again, thanks.
    Jan 2006
    Istanbul
    Lightbulb
    datapin    VAR PORTB.1
    led        VAR PORTA.5
    Tosend     VAR BYTE
    char       VAR BYTE
    RS_state   VAR BIT
    GOSUB InitLCD
        for char = 32 to 90
            gosub SendData
            toggle led
        next char
    InitLCD:
        RS_state = 0
        char = $30
        PAUSE 6
        PAUSE 1
        PAUSE 1
        GOSUB SendCommand
        GOSUB SendCommand
        GOSUB SendCommand
        GOSUB SendCommand
    sendHalfnibble:
        GOTO sendtolcd
    SendCommand:
        RS_state = 0
        GOSUB ToLCD
        PAUSE 2
    SendData:
        RS_state = 1
    ToLCD:
        gosub sendtolcd
        gosub sendtolcd
    SendToLCD:
        low latchpin
        low latchpin
        low latchpin
        pauseus 50
    Attachment 4867
    Darrel,
    Would that be possible to use 595_LCD routine (above) with a Hijacked LCDOUT command?
    Something like your LCDAnypin hijacking.
    ________
    Quote Originally Posted by sayzer View Post
    Yes it would ... with some modification.
    But you may want to check out this post from Guido which uses a 74xx164 shift register and only uses 2 pins on the PIC with the HighJack routines.
    http://www.picbasic.co.uk/forum/show...5344#post95344
    Feb 2008
    Hi coders,
    yepp, it was the darn LC display. I tried the 1602, and the code works. *grnnpgf* I spent 5 days of trying for nothing...
    Anyway, the next goal is to store strings in PICs memory, and shift them out to the LCD. Darryls "STRINGS.PBP" looks very interesting. I think I use his routines again...
    I'll write again.
    Jan 2006
    Istanbul
    Thank you Darrel.
    Guido's way did not work in my simulator. I will make the real circuit assuming that the simulator could not simulate it.
    Feb 2008
    The circuit and the program work now. It's easily possible to drive up to three LCDs with only three I/O pins of the µC. Darryls "strings.pbp" work with only minor changes for my program. Thanks again, Darryl.
