Originally Posted by
Kamikaze47
Unfortunately, no difference.
did you clean the board carefully with acetone to wipe off any solder stripper ??? especially under the caps ...
next step will be verify your caps value ( SMD not marked ...) and Xtal data ...
may be could we have an eye on your program ??? ...
BTW ... could you try to run the PIC @ 10 mhz ( HS_OSC ) ... just to see if any life aboard.
