it seems to be running happily at 64hmz
i dont understand why since i tried 2 different 10mhz crystals
The only thing to watch when overclocking is that things like serial comms ad the like often wont work. I had an 18F4580 running on a 20Mhz xtal with the HS_PLL setting - whilst it wasn't probably running at 80Mhz, it was dammed fast- but non of my serial comms would work until I replaced the 20Mhz xtal with a 12Mhz one. (as spotted by Alain)
I was going to suggest that you tried using the xtal from the breadboard that you know was a proven crystal... but now you seem to of resolved the problem. - I have to agree with Alain, I would only purchase from a large component retailer (RS in my case).
I'm still noticing something strange.
When I turn it on for the first time in half an hour, it takes about 3 seconds to start running.
If I then turn it off, and back on it starts right away.
Still something strange going on.
Hi, Malc
your problem was setting correctly the OSC related registers ... not a Xtal problem ...
as you were running @ ... 4x 12 Mhz !!!
for PBP ... it is not overclocking, as those frequencies are in the compiler's list ...
@ Kamikaze
looks there's a supply stability or glitches problem that doesn't allow the PLL to stabilize quickly ... add a 10/22 µF Tantalum bead as close as possible to the PIC !!!
You also can poll for the PLL stability flag before allowing your program to run ... ( for execution sake )
