3 breadboards! Yikes...
I'm putting female headers on mine for the analog pins.
I could suck-it-in for a version that would drop right into a standard single breadboard, but I'm just not in the mood to sit & hand-assemble 30+ boards under a microscope for a freebie...
And - it's really a drag for someone that gets one to replace any parts < 0805 by hand.
If someone prefers SMD switches, I can change that, but they're normally more expensive. I definitely do not want the SMD USB-A connector. These things tend to rip-off & lift traces with just a little wiggle. I tried really hard to keep it super cheap, but I'm open to feedback if someone wants something changed.
You should be able to edit/view it with the free version of DipTrace. The raw file is there if anyone wants to have a go at making it better or smaller.
Walter - the mini USB connectors are a pain, and not everyone has those teeny cables. I used a standard through-hole A type for stability, and it's easier for me to assemble. And - if we used the SMD mini USB connector, it's way too easy to rip-off the board if you lift up on the USB cable. These need to be installed in an enclosure (like say a PICKit2 or 3) where the enclosure itself provides support.
