Is there something I can do that will make LCD_AnyPin work with PBPL?
This is the test code im using.
It compiles and works fine with regular PBP, but I get this error when I use PBPL:Code:LCD_DB4 VAR PORTA.4 LCD_DB5 VAR PORTA.2 LCD_DB6 VAR PORTA.3 LCD_DB7 VAR PORTB.0 LCD_RS VAR PORTA.0 LCD_E VAR PORTA.1 LCD_Lines CON 2 LCD_DATAUS CON 50 LCD_COMMANDUS CON 2000 INCLUDE "LCD_AnyPin.pbp" LCDOut $FE,1,$FE,2,"Hello World!" END
Any ideas? I suspect I'll need to edit another PBP file, but i'm not sure.Code:ERROR: (HighJacked-LCDOUT Not found in PBPPIC??.LIB)
