LCD_AnyPin.pbp
+ Reply to Thread
Results 1 to 40 of 113
Thread: LCD_AnyPin.pbp
    Quote Originally Posted by Kamikaze47 View Post
    Is there something I can do that will make LCD_AnyPin work with PBPL?
    Any ideas? I suspect I'll need to edit another PBP file, but i'm not sure.
    You are right. You need to edit pbppi18l.lib as you did pbppic18.lib, and it should work. Don't forget to save a copy, just in case.
    http://www.scalerobotics.com
    Perth, Australia
    Thanks scalerobotics. That worked
    sinoteq's Avatar
    sinoteq Guest
    Default Highjack time :)
    Hi
    I am running out of pins so it is time to implement LCD_Anypin but I have a question. Do I need the standard PBP defines also? You know the DEFINE LCD_REG, DEFINE LCD_BITS and so on.
    I want to interface a 4 lines 16 characters display to my project using a 4 bit databus.
    My guess is I need DEFINE LCD_BITS 4 and DEFINE LCD_LINES 4
    This will be the second DT code I include, the fist one is of course DT-Interrupts and I bet LCD_Anypin will be equally usefull.
    Read the sample code and comments here
    http://www.picbasic.co.uk/forum/show...3345#post43345
    1 = 2
    2 = 4
