serial polling
Results 1 to 7 of 7
Thread: serial polling
    Jun 2009
    o.k basicly the ecu, has a serial connection, standard 9600,n,8,1, All the data about the engine comes down via serial, apparently it sits in a buffer till someone polls it for the info. its 120bytes in total, so i would probably have to poll it via serial drag all the info then filter out the bit i want.
    Quote Originally Posted by mataston View Post
    o.k basically the ecu, has a serial connection, standard 9600,n,8,1, All the data about the engine comes down via serial, apparently it sits in a buffer till someone polls it for the info. its 120bytes in total, so i would probably have to poll it via serial drag all the info then filter out the bit i want.
    It would be useful to know the Make, Model of the vehicle OR what data must be sent to activate the ecu to send. Old GM obd1 systems would send if you ground a certain wire on the ALDL, OBDII is a bit more complicated. I suggest you use the Google search engine (the one which will search just this forum) as this has been done before by others here.
    http://www.google.com/custom?q=&sa=G...picbasic.co.uk
    Jun 2009
    its called megasquirt
