Question about DT's Interrupts
Results 1 to 7 of 7
    Quote Originally Posted by jellis00 View Post
    However, DT told me in one post that you can't use his USB_Handler to awaken from sleep mode and I should sense the connection of the USB cable with an RB change interrupt and then in the ISR for the RB change do an @RESET to somehow start the USB service.
    Yes I did.
    But let's pretend I didn't.
    You can put the PIC to sleep, and it will re-enumerate when re-connected.
    The main oscillator is stopped in sleep mode, so the USB module's clock also stops.
    You can also place the USB module in SUSPEND mode to reduce the current from the USB module. That's done in response to an IDLEIF, currently used to determine un-plugged state in DT_HID.
    When the USB cable is plugged in, you'll get ACTVIF interrupts (a signal to RESUME from SUSPEND mode).
    So you don't even need to connect USB +5V to an INT pin.
    The USB module can detect the changes.
    It's just that you have to do it. Nothings automatic.
    Mar 2009
    Colorado
    Default Is this right?
    Darrel, I thought I understood how to do this, but am getting all kinds of assembler errors when I try to compile. Here are the applicable excerpts of code I created to try to follow your suggestion. Can you please tell me where this went wrong??
    First I set up my DT_INTS as follows with intention of using a USB_ACTV_INT from your DT_INTS to wake up the MCU and run the USB interface when connected.
    INT_LIST  macro      ; IntSource,            Label,  Type, ResetFlag?
            INT_Handler   USB_Handler
            INT_Handler   USB_ACTV_INT  _ACTVIFhandler,   PBP,  yes
            INT_Handler   INT2_INT,             _Range,   PBP,  yes
            INT_Handler   HLVD_INT,           _LowVolt,   PBP,  yes
    endasm
    Then I created this handler for the USB_ACTV_INT.
    ACTVIFhandler:
        IF LCD_Flag = 1 Then ' This code block FOR TESTING ONLY
            LCDOut $fe,1' Clear Display
            LCDOUT $fe,Line1,"USBPlugged"
            LCDOUT $fe,Line2,"interrupt"
        ; put code here to process USB interrupt
         FOR X = 0 to 1000       ; Check for incomming USB data while waiting
    @       ON_USBRX_GOSUB  _HandleRX
            PAUSE 1
                New_PORTB2 = PORTB.2         ; Check PORTB.2 pin for change
                IF New_PORTb2 != Old_PORTB2 THEN  ' PortB.2 changed
                    Old_PORTb2 = New_PORTb2
                    ' NEXT STATEMENT NOT WORKING...CHECK WHY!!
                    ARRAYWRITE USBTXBuffer, ["USBDemo"]
                    GOSUB WaitToSend     ' Send data set about one/sec
                    ' Send device ID to PC
                    ' Send current Date/Time to PC
                    ' Send each EEPROM stored date stamped range measurement to PC
                    ' Send current BATTLOW indicator to PC
                    ARRAYWRITE USBTXBuffer,[0,deviceID1,deviceID2,Mon,date,Yr, _
                                       hr,MINs,sec,stamp,rng0,rng1,BATTLOW,0,0,0]
                    GOSUB WaitToSend
        NEXT X
        IF J > 222 THEN     ' If reached maximum EEPROM usage location...
            J = 16            ' ..reset pointer to start of range data
        Endif
        READ j, stamp       ' Read date stamp of measurment
        READ J+1, rng0      ' Read range measurement from EEPROM
        READ J+2, rng1
        Pause 10
        J = J + 3
        ' Send Data to PC
            ' Send each EEPROM stored range measurement to PC
            ARRAYWRITE USBTXBuffer,[0,deviceID1,deviceID2,mon,date,yr, _
        GOSUB SendIfReady
        Pause 500      ' Delay for user to view LCD
    @ INT_RETURN
    Then I modified my Main loop per follows to put MCU in sleep mode whenever not plugged in to USB or not receiving an external interrupt from the Real-time-clock (INT2).
    @    INT_ENABLE   USB_ACTV_INT ; enable USB activity interrupt on plug-in
    @    INT_ENABLE   INT2_INT     ; enable external (INT) interrupts
    ENABLE DEBUG
    '--------------------[ Begin Main Program Loop ]-------------------------
    ;@ StartSize(MainLoop)    ; FOR TEST ONLY
         PAUSE 100 ' Without this Pause, there's nothing to keep the WDT clear.
                   ' HIGH, LOW & GOTO don't generate CLRWDT instuctions.
            GOSUB DisplayDateTime
         ' Store current date/time in EEPROM
            WRITE 242, Mon
            WRITE 243, Date
            WRITE 244, Yr
            WRITE 245, hr
            WRITE 246, MINs
            Write 247, sec
        ' Place code here to put MCU and Ultrasonic Ranger in SLEEP mode.
        ' while waiting for clock or USB interrupt to wakeup from SLEEP mode.
        ' IDLEIF is used in the DT_HID code to detect unplugged state. If unplugged,
        ' per DT, it is safe to put the USB module in suspend mode before sleep
            IF IDLEIF THEN     ' USB is in unplugged state..
               UCON.1 = 1      ' puts USB module in suspend mode to save power
        ' Enable the USB ACTVIF interrupt to awaken MCU when USB connected
            UIE.2 = 1
        ' Perform following steps to save power during Sleep mode
            CVRCON = %00000000 ' Set Voltage Reference for minimum power consumption
                               ' Disable CVref during Sleep to save power
            ADCON1= %00000000  ' Set PortA to Analog I/O to save power during Sleep.
            CMCON = %00000111  ' Disable comparators
            HLVDCON = %00000000' Disable HLDV register
            TRISB = %11111111  ' Set all PORTB pins to inputs
            TRISC = %11111111  ' Set all PORTC pins to inputs
            PortA = %11111111  ' Set TOCK1, MCLR & all PortA pins High before Sleep
                               ' to save power
            PortB = %11101111  ' Set all Port B & C pins High to save power
            PortC = %11111101  ' except RB4 & RC2.
            @ sleep
            @ NOP
        ' Microcontroller is in Sleep State awaiting next INT2 or USB plug-in
        ' INT2 interrupt from RTC will log a range measurement and go back to sleep
        ' ACTVIF interrupt from USB senses that USB connector is plugged in
        ' and will dump data logged in EEPROM to PC via USB interface and then go
        ' back to sleep when the USB cable is disconnected.
    GOTO Main
    Here are the assembler errors I get when I attempt to compile with above code:
