Opto interrupter ;>
Results 1 to 10 of 10
Threaded View
  1. #3
    The problem with your current aproach is that if the input stays high longer than it takes for the program to cycle it will keep on counting. Think of it, the input goes high, the variable is incremented and the program starts over, the input is still high, the variable get incremented and the program starts over and so on.
    We're talking micro seconds here so if one pulse from your opto-interupter is 2ms long you may count from 0-10 in one single pulse. You need to wait for the input to go high, increment your count variable then wait for the input to go low again before you allow another count. Something like:
    loop:
      if opto = 1 then
        counts = counts+1
        if counts >=10 THEN
          high led
    While opto = 1      'Loop here until input goes low.
        Wend
    goto loop
    A better way though would be to use one of the PICs internal timers configured as a counter and simply let it count the pulses. Have a look at the TMR1 section of the datasheet.
    About your code then, you haven't DEFINEd the oscillator speed and there's a colon missing after the loop label...
    EDIT: OK, I give up....why the heck does the editor keeps inserting code tags on it's own in the middle of a section already surounded by code tags??
    Last edited by HenrikOlsson; - 4th June 2010 at 11:26. Reason: The bloody editor keeps inserting code tags on it's own - AAARGH.
