AY0438 Display Driver
Results 1 to 14 of 14
    Aug 2009
    Default AY0438 Display Driver
    I have a Glass type display with a Microchip AY0438 display driver. I found the assembly code for this chip on Microchips site, but I'm bot very good with assembly. Can anyone offer a code example of how to use this chip with PBP? I have used the LCDOUT comand with the 44780 type displays, but i have not used this type of display before.
    Terry
    Quote Originally Posted by tallen View Post
    Terry
    Hi Terry,
    I used the shiftout command. Sorry I don't have an example on this
    PC. I will look for some code I have and post it later.
    Mark
    Miami, Florida USA
    tallen,
    Yes, I have used this chip before. The LCDOUT command is for alphanumeric LCD displays, for example a 16x2 characters display. This chip AY0438 is to drive 7-segments LCD displays. What type of display do you want to drive?
    Aug 2009
    Its a 7 seg LCD that has a Microchip AY0438 driver with it.
    Terry
    Miami, Florida USA
    Terry
    Then, you need to look at the datasheet of the LCD with the AY0438 in it. Look at figure 4 of the AY0438 datasheet. This figure shows you how to control the 32 segments. If I remember correctly, you have to connect the LCD(Phi) to the clocking signal for it to work. How many digits does the LCD have?
    Terry
    Terry,
    Try this code. It is for a 4 digit seven segment display.
    Mark
    Aug 2009
    i'm struggling with this code. It is a 4 digit 7 segment display. The display just seems to roll continiously very fast. I put in a pause to slow it down. I removed the "IF Total = 9999 then Temp = 0" and the "Temp=Temp+1. I put it TEMP = 1234 hoping to dispaly 1234, but all I see is just jumbled up numbers. I put in TEMP = 1 and see PPP. As you can Tell I don't understand this lookup and shiftout code. Any Ideas?
    Terry
