AY0438 Display Driver
Results 1 to 14 of 14
Threaded View
  1. #10
    Terry,
    Try taking the "0" out of each of these lines. Then try your Temp = 1234
    'SEVEN SEG LOOKUP
    LookUp ONES,[63,6,91,79,102,109,124,7,127,103,0],LCD_THOU
    LookUp TENS,[63,6,91,79,102,109,124,7,127,103,0],LCD_HUNS
    LookUp HUNS,[63,6,91,79,102,109,124,7,127,103,0],LCD_TENS
    LookUp THOU,[63,6,91,79,102,109,124,7,127,103,0],LCD_ONES
    I did this a long tme ago so I don't remember why I added the 0. Hope you get it going.
    Regards Mark
    Add:Like Robert said the LCD may be connected different than my code.
    I used LCD segment A, Digit 1 = Segment 1 Pin 39 AY0438 and
    LCD seg B = Segment 2 pin 38 AY0438 and so on.
    Post your asm code, we can probably see how its connected by the look up tables at
    the bottom of the listing.
