How to connect Buzzer to PIC?
Results 1 to 33 of 33
    Apr 2010
    Default I have a similar circuit
    I have taken apart a kitchen timer, and it has a similar circuit to the piezo buzzer mentioned earlier in this thread. There is a large inductor coil attached where the buzzer is.
    In this picture:
    http://www.picbasic.co.uk/forum/atta...9&d=1264966885
    Can someone tell me what is the purpose of Q1? Looks to be a surface mount NPN transistor.
    One of the leads to the piezo is always high, and the other one seems to be attached to the collector (not emitter!) of this transistor with the emitter going toward the IC through R1, although I could have my pinouts wrong.
    How does the IC control the PWM going to the piezo by means of the transistor?
    Thanks!
    This is a circuit I use. When the NPN is turned on the inductor is energized, turn off the transistor and a large counter inductive voltage spike is generated.
    As stated in earlier posts its best to drive the piezos at the resonance frequency. Your picture maybe different
    Your question about the IC control. The transistor acts as a switch, controlled by the IC. More important it protects the IC as a buffer with it's
    higher current handling ability
    Quote Originally Posted by Telemachus View Post
    In this picture:
    Thanks!
    You've got the pinout wrong... the 22K resistor is on the base, the emitter looks to be tied to ground (check it with a meter). It sounds like the piezo is in the collector making it an open collector. You can tie the coil in parallel with the piezo to get the same flyback effect that Mark_s was talking about. Again, it's resonant so you have to play with the frequency to get it to "go"...
    Apr 2010
    Quote Originally Posted by mtripoli View Post
    Thanks, after some more research, I realized the true pinout.
    Actually, what I am trying to do is to remove the coil and piezo entirely, and have the transistor act as a switch to turn on and off a higher voltage (3.3volts) that will be fed to the input pin of a PIC. Therefore, when the kitchen timer goes off, the PIC will read the PWM output as a digital signal to run a routine prior to resetting the kitchen timer to start counting again.
    What I have come up with so far is to disconect the coil from the transistor's collector, mount instead a 3k3 resistor between the collector to PIC VDD (3.3V) and connect the PIC input pin on transistor's colector. With the emitter of the transistor connected to GND (I will ground the PIC to the CMOS circuit). That way, when the timer goes off, it should trigger a "buzzer" that in non audible, but compatible with the VDD voltage that my PIC can read digitally.
    This is a timer circuit to snap the shutter on a Cannon SLR camera, and I have found that using the kitchen timer is cheaper than it would be to buy the LCD and buttons needed build the circuit completely based on a PIC.
    A digital Canon SLR? If I recall, there is a group of pads inside the the battery door. Bridging these pads results in focus adjust and shutter release. I used a 1K resistor (or something) to play around with this. I was going to make an RF remote control for my camera but got side-tracked with something else (about 5 years ago). There's a bunch of info on the net about this stuff. I think you can use just a relay to do this...
    I'm missing the point of using the kitchen timer. You can do everything you want with just the PIC...
    Apr 2010
    The point of the timer is an LCD screen and push buttons for $2 at local discount store.
    I have already created one that is solely pic based, sets the camera off on intervals based on a potentiometer, from 1 to 255 seconds. I was next going to install and LCD screen with push buttons to do it all digitally, and found that the kitchen timer is cheaper than buying those parts individually.
    The timer has button that when pushed at the end of the cycle, restarts the timer. Essentially, the button is connecting a pin on the CMOS to the VDD of the circuit. I may be able to use another transistor and have the timer reset itself without even using a pic...
  1. PIC keeps resetting when executing subroutine
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 27th August 2009, 07:03
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. how to connect ac sensor to PIC ?
    By iugmoh in forum Schematics
    Last Post: - 1st June 2008, 18:35
  4. connect microphone to pic?
    Last Post: - 7th January 2008, 08:33
