Fast External Memory
Results 1 to 36 of 36
    May 2007
    Which PIC are you using? To use that static RAM, you will need one with an External Memory Bus - typically an 80-pin TQFP device.
    Feb 2010
    USA, New England
    Which PIC is yet to be decided. I work a lot with the 18F452 currently. I'm not opposed to using a larger PIC, but 40 pins ought to cover everything. I didn't think I needed to use an explicit memory bus, I presumed that I could just control the the interface directly. I suppose there would be speed disadvantages, though.
    Best Regards,
    Paul
  1. External memory routines?
    By John_Mac in forum mel PIC BASIC Pro
    Last Post: - 4th April 2009, 03:13
  2. external Memory
    By jerryf in forum mel PIC BASIC Pro
    Last Post: - 29th November 2008, 03:06
  3. PBP/PBPL and external memory
    Last Post: - 11th November 2007, 06:31
  4. PBP External Memory Bus Support
    By ALFRED in forum mel PIC BASIC
    Last Post: - 25th December 2006, 09:42
  5. external memory
    Last Post: - 15th April 2006, 01:51
