Fast External Memory
Results 1 to 36 of 36
    Feb 2010
    USA, New England
    Art,
    Not a bad idea, but that's a lot of pins (and capability) going to waste. I went and actually tested some code and I can't *quite* fit an array of 1024 LONGs, but I can break it down and get 1024 24-bit values.
    This discussion started me looking around, and I'm thinking of picking up a few of these to try: http://search.digikey.com/scripts/Dk...=800-1433-5-ND
    Robert,
    Thanks for the input, but that device looks way too slow.
    Best Regards,
    Paul
    May 2007
    Which PIC are you using? To use that static RAM, you will need one with an External Memory Bus - typically an 80-pin TQFP device.
    Feb 2010
    USA, New England
    Which PIC is yet to be decided. I work a lot with the 18F452 currently. I'm not opposed to using a larger PIC, but 40 pins ought to cover everything. I didn't think I needed to use an explicit memory bus, I presumed that I could just control the the interface directly. I suppose there would be speed disadvantages, though.
    Best Regards,
    Paul
    May 2008
    Italy
    I need to keep track of two large arrays (1024 elements) of LONGs in a two-channel pulse height analyzer. As each value comes in I need to increment that element by one. For example, if ADC1 returns a value of 258 I need to get the value of MyLongArray[258] and add 1 to it.
    I wonder why you need a long variable for this application? Once that an array has reached a count of 255 (one byte) statistically your pattern is not going to change much till when your long will overflow.
    I am currently doing this by streaming the data out to a PC and letting the PC do the work of storing and updating the array. I'd like to move this into a self-contained board instead.
    Surely you are doing the transfer via serial port, I don't see why a serial eeprom shouldn't be able to cope with the PC baud rate.
    Al.
    Feb 2010
    USA, New England
    Quote Originally Posted by aratti View Post
    I wish! On the front end is a radiation detector. Features within the array (or spectrum, if you will) become better defined with larger accumulations, and the statistics of the measurement do improve. Your right that a long variable is probably overkill, but a word variable is certainly too small. I've been working with 512-element arrays of 24-bit values (a word and a byte) and that is probably enough, but more is better right?
    Al.
    If it were just sending the data one way, as it does to the PC, you'd be correct. With serial memory the value at the location must be read, incremented, then re-written. I timed it out a couple of weeks ago and it was horrendously slow (relatively speaking) using I2CREAD and I2CWRITE.
    Best Regards,
    Paul
    P.S. I manged not to say "don't call me Shirley." 8^)
    USA - Arizona
    The 18F452 should have plenty of memory; and all the banks can be accessed linearly.
    For 1024 x 32-bit (long) words; a 32K serial EEPROM (e.g. 25AA320) would do. They can be clocked up to 10MHz (all in the HW SPI) which should be more than needed.
    If you strictly need RAM (not long-term storage) then a serial RAM (e.g. 23A640) should do. Again SPI interface at speeds up to 20MHz.
    I still think you should have more than enough storage on an 18F452.
    Paul,
    Have a look at this digital o-scope project. He uses a 16Kx9 fifo, maybe
    something you can adapt to your application?
    http://stephan.walter.name/files/pub...so-project.pdf
    Feb 2010
    USA, New England
    Quote Originally Posted by mark_s View Post
    Paul,
    Sweet! Now I have some reading material for the evening. Even if it's not applicable to this project it looks very interesting.
    Best,
    Paul
    Feb 2010
    USA, New England
    Quote Originally Posted by languer View Post
    Doh! I didn't read enough of the manual! I somehow thought the hardware SPI and the USART shared the same pins and I didn't want to give up the USART. Now I see that it's different pins for that. I think you've pointed me to the solution. Thanks! And I apologize for not RTFMing thoroughly enough...
    Sadly, no. Try compiling just this line for an 18F452:
    MyArray var WORD[1024]
    You get the message "ERROR: Unable to fit variable MyArray". It'd be awesome if you could show me I'm wrong here as well.
    Best,
    Paul
    Quote Originally Posted by prstein View Post
    Robert,
    Best Regards,
    Paul
    You can use page writes with the AT24C1024, could that help?
    Features
    • 256-byte Page Write Mode (Partial Page Writes Allowed)
    Aug 2003
    If eight pins is too much you could use a 4 bit interface.
    Still much faster than any I2C or serial EEPROM, particularly when you
    have to wait 10ms after a write cycle.
    If you read a value and then update that value, you are supposed to wait 10ms right there.
    No reason why the pic acting as a RAM chip couldn't perform other tasks until
    it is interrupted,
    as long as there's enough RAM left in both chips to run the program as well.
    I'm sure I've asked about external RAM on this board before (or on the old picbasic list).
    It would be nice to have a fast pic compatible RAM chip, as well as an FPU
    (another thing I've asked about).
    I'm sad that the pic32 chips don't even have an FPU (something I expected).
    USA - Arizona
    Not to keep beating the same drum ...
    I suggest you look at something like the 23A640. You can do sequential reads and sequential writes. And all this over SPI. At 10MHz (and four lines - max), a 32-bit transfer is 3.2uS (that should be pretty fast).
    From datasheet:
    If operating in Sequential mode, the data stored in the memory at the next address can be read sequentially by continuing to provide clock pulses. The internal Address Pointer is automatically incremented to the next higher address after each byte of data is shifted out. When the highest address is reached (1FFFh), the address counter rolls over to address 0000h, allowing the read cycle to be continued indefinitely.
    If operating in Sequential mode, after the initial data byte is shifted in, additional bytes can be clocked into the device. The internal Address Pointer is automatically incremented. When the Address Pointer reaches the highest address (1FFFh), the address counter rolls over to (0000h). This allows the operation to continue indefinitely, however, previous data will be overwritten.
    This, or something similar, should fit your needs.
    Feb 2010
    USA, New England
    it is interrupted,
    Hi Art,
    I think the hardware SPI port might do it. I'm going to try these: http://www.mouser.com/ProductDetail/...1pcR43MBP1g%3d. I don't care so much that they're non-volatile but they are much faster at writing than standard EEPROM.
    Best,
    Paul
    USA - Arizona
    Yeap, I must have been smoking something. No way to fit it in.
    The part you highlighted is very cool (fast as SRAM, but non-volatile like SEEPROM). The 16k part will be great for 1024 WORDS, but will only fit half of the 1204 LONGS.
    Feb 2010
    USA, New England
    Default Followup
    Just wanted to followup with news of success. After a comedy of wiring errors I finally got an F-RAM going using shiftin and shiftout. Once I confirmed that as working I changed the code to use the hardware SPI port. It is blazingly fast. I'm using running the 18F452 at 20MHz so I can "only" run with a 5MHz clock. Haven't actually timed it (yet) but I think it'll all work out just fine.
    If there's any interest I'll post the code in the Code Examples section.
    Thanks again, everyone, for all the suggestions.
    Best Regards,
    Paul
    Sep 2007
    USA, CA
    I have used the i2c version of the FRAM and liked it. I had to switch when I needed more memory, though... it can cost over 10x the price of an atmel eeprom.
    May 2009
    Best Regards,
    Paul
    Hi Paul: I am actually trying to figure out the hardware SPI module for F-RAM. So can you share your codes for that part? I appreciate it very much!!!
    Vinson
    May 2009
    Best Regards,
    Paul
    Actually I could use SHIFTIN and SHIFTOUT for accessing the F-RAM memory, as you told, it is a "comedy" wiring error, it seems like totally reversed. But for hardware SPI, I think the MISO,MOSI connection should be followed, right? In your code, it is connected like this.
    Vinson
  1. External memory routines?
    By John_Mac in forum mel PIC BASIC Pro
    Last Post: - 4th April 2009, 03:13
  2. external Memory
    By jerryf in forum mel PIC BASIC Pro
    Last Post: - 29th November 2008, 03:06
  3. PBP/PBPL and external memory
    Last Post: - 11th November 2007, 06:31
  4. PBP External Memory Bus Support
    By ALFRED in forum mel PIC BASIC
    Last Post: - 25th December 2006, 09:42
  5. external memory
    Last Post: - 15th April 2006, 01:51
