TRIS setting for the DS1302
Results 1 to 29 of 29
    Default is it the code ?
    @Art
    I decided to give Cocacolakid's code a whirl,sadly time stand still :-( display is stuck at 00:00:80
    I think it's because of the if statement here:
    if portb.4 = 1 then START ' Set initial clock start up if jumper is present
    So after removing it since I have no jumper there and re-programming the PIC.
    The display shows:
    00:30:00 and time stands still :-(
    Here's the code I am using :
    'using pic18f4520
    'Ocsillator selections here
            OSCCON = $70            'Int CLK 8MHz
            OSCTUNE.6 = 1           'PLL 4x
            ADCON1= %00001111       '$0F = disable A/D converter
            cmcon   =   7
            INTCON2.7 = 0     'switch pull-ups ON
    'END of oscillator selections
      'timer/oscillator defines
            DEFINE OSC 32            '4x 8MHz
    'END of timer/oscillator defines
    'Port IO directions and presets for port pins begin here
    'TRISX = %76543210   << tris bit order numbering
    'TRISA = %11111111       'All pins are outputs
    'Define port pins as inputs and outputs ...
    'example only - TRISB = %00001111 ;Make 'B4-B7 outputs, B0-B3 inputs
    TRISA  = %00000000 'assigned to LCD
    TRISB = %11111111  'for 4x4 keypad all input
            TRISC = %10000000
            TRISD = %00000000
            TRISE.0 = 0
            TRISE.1 = 0
            TRISE.2 = 0
    'End of Port IO directions and presets for port pins begin here
    'LCD defines begin here
            DEFINE LCD_BITS 4 	'defines the number of data interface lines (4 or 8)
            DEFINE LCD_DREG PORTD 	'defines the port where data lines are connected to
            DEFINE LCD_DBIT 4 	'defines the position of data lines for 4-bit interface (0 or 4)
            DEFINE LCD_RSREG PORTD 	'defines the port where RS line is connected to
            DEFINE LCD_RSBIT 2 	'defines the pin where RS line is connected to
            DEFINE LCD_EREG PORTD 	'defines the port where E line is connected to
            DEFINE LCD_EBIT 3 	'defines the pin where E line is connected
            'DEFINE LCD_RWREG 0 	'defines the port where R/W line is connected to (set to 0 if not used)
            'DEFINE LCD_RWBIT 0 	'defines the pin where R/W line is connected to (set to 0 if not used)
            DEFINE LCD_COMMANDUS 2000 	'defines the delay after LCDOUT statement
            DEFINE LCD_DATAUS 200 		'delay in micro seconds
    'END of LCD DEFINES
    'includes begin here
            INCLUDE "modedefs.bas"
            include "c:\pbp\samples\keypad.bas"
    'end of includes
    DEFINE HSER_SPBRG 207 ' 2400 Baud @ 32MHz, 0.17%
    '-------------------------- Clock Variables ---------------------------------
    clk     var portC.3 ' DS1302 Clock Pin
    dq      var portC.4 ' DS1302 Data Pin
    rst     var portD.1 ' DS1302 Reset Pin
    '----------------------- Write Commands For DS1302 --------------------------
    writectrl con $8E ' Control byte
    writeram con $80 ' Write to RAM
    writeprotect con $00 ' Write-protect DS1302
    writesec con $80 ' Write seconds
    writemin con $82 ' Write minutes
    writehour con $84 ' Write hour
    writedate con $86 ' Write date
    writemonth con $88 ' Write month
    writeyear con $8C ' Write year
    '------------------------- Read Commands For DS1302 -------------------------
    readsec con $81 ' Read seconds from DS1302
    readmin con $83 ' Read minutes from DS1302
    readhour con $85 ' Read hours from DS1302
    readdate con $87 ' Read date from DS1302
    readyear con $8D ' Read year from DS1302
    readmonth con $89 ' Read month from DS1302
    '------------------------------ Time Variables ------------------------------
    mem var byte ' Temporary data holder
    outbyte var byte ' Second byte to ds1302
    reg_adr var byte ' First byte to DS1302
    date var byte ' Date variable
    ss var byte ' Seconds variable
    mm var byte ' Minutes varibale
    hh var byte ' Hours variable
    mo var byte ' Month variable
    yr var byte ' Year variable
    '------------------------ Initial Settings For Ports ------------------------
    low rst ' Set reset pin low
    low clk ' Set clock pin low
    '----------------------- Set Initial Time Variables -------------------------
    'if portb.4 = 1 then START ' Set inital clock start up if jumper is present
    reg_adr = writectrl ' Set to control byte
    outbyte = writeprotect ' Set turn off protection
    gosub w_out ' Send both bytes
    reg_adr = writesec ' Set to write seconds register
    outbyte = $00 ' Set to write 00 to seconds register
    gosub w_out
    reg_adr = writemin
    outbyte = $30
    gosub w_out
    reg_adr = writehour
    outbyte = $00
    gosub w_out
    reg_adr = writedate
    outbyte = $01
    gosub w_out
    reg_adr = writemonth
    outbyte = $01
    gosub w_out
    reg_adr = writeyear
    outbyte = $00
    gosub w_out
    reg_adr = writectrl
    gosub w_out
    start:
    reg_adr = readsec ' Read seconds
    gosub w_in
    ss = mem
    reg_adr = readmin ' Read minutes
    gosub w_in
    mm = mem
    reg_adr = readhour ' Read Hours
    gosub w_in
    hh = mem
    reg_adr = readyear ' Read Year
    gosub w_in
    yr = mem
    reg_adr = readdate ' Read Date
    gosub w_in
    date = mem
    reg_adr = readmonth ' Read Month
    gosub w_in
    mo = mem
    lcdout $fe,1,"TIME:",HEX2 hh,":",HEX2 mm,":",HEX2 ss
    goto start
    '----------------------- Time Commands Subroutines --------------------------
    w_in:
    mem = reg_adr ' Set mem variable to reg_adr contents
    high rst ' Activate the DS1302
    shiftout dq,clk,0, [mem] ' Send control byte
    shiftin dq,clk,1, [mem] ' Retrieve data in from the DS1302
    low rst ' Deactivate DS1302
    w_out:
    mem = outbyte ' Set mem variable to outbyte contents
    shiftout dq,clk,0, [mem] ' Send data stored in mem variable to DS1302
    I have attached my circuit diagram too ...perhaps that's where the mess-up is ?
    Will try asm code as well and feedback
    Also going to source a DS1307 and DS1337C tomorrow and later this week, will post an update asap.
    Kind regards
    Dennis
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Dennis View Post
    Kind regards
    Dennis
    Dennis,
    I'm using a DS1307, well one of MicroElektronica's RTC modules for the EasyPIC5 board and have the following example displaying time and date on a 16 x 2 LCD. I've only included the code for the RTC as there are loads of examples for hooking up an LCD.
    SDA var PORTC.1                     ' RTC data
    SCL var PORTC.0                     ' RTC clock
    TRISC= %00000011
    DB0 var byte[8]
    CMCON = %00000111                   ' Comparators = off
    gosub write_1307
    read_1307:                          ' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
    I2CREAD SDA,SCL,$D1,$00,[STR DB0\8] ' Read 8 bytes from DS1307
    lcdout $fe,1,"Time=",hex2 DB0[2],":",hex2 DB0[1],":",hex2 DB0[0]    'bit 0=sec, bit 1=min, bit 2=hrs
    lcdout $fe,$c0,"Date=",hex2 DB0[4],":",hex2 DB0[5],":",hex2 db0[6]  'bit 4=day, bit 5=month, bit 6=year
    goto read_1307
    Write_1307:                          ' Set time & date to 19:00:00  14th Feb 201
    I2CWRITE SDA,SCL,$D0,$00,[$00,$00,$19,$7,$14,$2,$10,$90] ' Write to DS1307
    pause 10
    RETURN                               ' Sec Min Hr Day D M Y Control
    I've had this running for some time in testing, and seems quite stable. One thing that needs developing further is a means of entering the date and time via push buttons or some other means, but at least you should be able to see the basic operation
    California, USA
    you don't need to read the registers of the DS1302 individually. You can grab the whole contents of the time register in one shot using "burst mode".
    high rst         ' Ready for transfer
    Shiftout IO, SCLK, LSBFIRST, [$bf] ' Read all 8 RTC registers in burst mode
    Shiftin IO, SCLK, LSBPRE, [rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, rtccontrol]
    low rst         ' Reset RTC
    That should load all the time info into your variables, rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, rtccontrol
    steve
    Default cool
    @Steve :-)
    Thanks for that info , actually saw your posts as I was sifting through the forum posts on DS1307 and DS1302 and I2Cread and I2CWrite , in fact I even tried it with my DS1302 (of course it didn't work since I2C is not what should be used for the DS1302) :-)
    Will try get something going for the DS1302 using that stub you posted and see what comes of it and will definitely give the DS1307 stubs a good bash when I get my DS1307.
    Regarding this line though ...
    , do you think they made much of a fuss about Valentines day back then ?
    I also wonder if this isn't how the Rosetta stone came about, some ancients trying to scribe stuff into a rock...it's just like us really .. we are making rock (Silicon) do some really wild things.
    Even wirelessly rock to rock ...INSANE hey ?
    Now to explain those cave paintings !
    Chat soon
    Kind regards
    Dennis
    malc-c's Avatar
    malc-c Guest
    Chat soon
    Kind regards
    Dennis
    LOL - must check my posts before uploading
    Default ok :-) definitely gonna try this tonight!
    @Steve ..apologies .. was actually asking Malc-c about valentines day :-)
    @ Steve , regarding these lines :
    low rst         ' Reset RTC
    I understand these
    LSBFIRST ' MODE 0 - Shift data out lowest bit first. Clock idles low.
    LSBPRE ' MODE 0 - Shift data in lowest bit first,Read data before sending clock. Clock idles low.
    But what is the [$bf] ?
    @Malc-c --to err is human :-)
    Kind regards
    Dennis
    California, USA
    $bf is the register address for clock burst mode read I believe.
    Do a search for $bf in the ds1302 data sheet.
    steve
  1. real time clock
    By maria in forum Code Examples
    Last Post: - 1st March 2022, 12:13
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  3. DS1302 16F628 Woes
    By idtat in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 14:15
  4. TRIS E setting for 18F2550
    Last Post: - 23rd May 2007, 07:47
  5. Is LCDOUT setting always al TRIS ?
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 19th June 2005, 17:02
