syntax error
Results 1 to 19 of 19
Thread: syntax error
    Exclamation
    Uno Momento por favor ...
    Are you using 14-bit?
    malc-c's Avatar
    malc-c Guest
    Sorry ?
    I'm using the code for the 16F877 we worked on, basically just wanting to sort the analogue pots and menus out.
    DEFINE ADC_BITS 10                ' Set-up ADC for fastest 10-bit results
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 5
    INCLUDE "DT_Analog.pbp"
    MaxSetPoint  CON 500              ' Pot fully clockwise
    MinSetPoint  CON 100              ' Pot fully counter clockwise
    ADbits = 14                       ' set A/D resolution to 14-bits
    CMCON = 7                         ' disable Comparators
    ADCON1 = %10000010                ' AN0-4 Analog, Right justify
    I think this should do it.
    Set ADchan before GOSUBing ...
    Result       VAR WORD
    GetSetpoint:
        GOSUB GetADC
        Result  = ADvalue*(MaxSetPoint - MinSetPoint)
        Result  = (DIV32 ADmax) + MinSetPoint
        Setpoints(ADchan) = Result
    hth,
    malc-c's Avatar
    malc-c Guest
    Darrel, I've tried you code, may not of put it in the right place
        FOR pid_Channel = 0 TO 3              ; cycle thru all sensors
            GOSUB SelectSensor
            GIE = 0                           ; disable interrupts before 1-wire
            @  DS1820_Convert                 ;   start a temperature conversion
            GIE = 1                           ; enable interrupts after 1-wire
        NEXT pid_Channel
    Result       VAR WORD
    GetSetpoint:
        FOR ADchan = 0 to 3
        GOSUB GetADC
        LCDOUT $FE,$C0, dec setpoints(0)>>1,"   "
        NEXT ADchan
    but the set point displayed in hyper terminal is still twice the value shown on the lcd.
    Default With 1 decimal place
    LCDOUT $FE,$C0, DEC setpoints(0)/10,".",DEC1 setpoints(0)//10
    malc-c's Avatar
    malc-c Guest
    Thanks.
    I tried changing the results value (dividing by 2 and then multiplying by 2) to no avail.
    How does dividing by 10 work out then ? If the result value was giving me a setpoints value of 100, but it was displaying 20.0 on the screen, dividing 100/10 gives 10 which would equate to 1.0 degree ??
    Just can't get my head round this... maybe I've been at it too long... or had too many glasses of wine !
    value = 100
    value / 10 = 10
    value // 10 = 0
    DEC value /10,".",DEC1 value//10 = "10.0"<hr>
    value = 342
    value / 10 = 34
    value // 10 = 2
    DEC value /10,".",DEC1 value//10 = "34.2"
  1. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 05:14
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Syntax error PIC16F684
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 21st September 2005, 19:54
