16F88 Compile error
Results 1 to 7 of 7
    Jun 2005
    Default 16F88 Compile error
    I have this error message when I compile a 16F88 program.
    ERROR: RAM END must be defined.
    ERROR: RAM BANKS must be defined.
    ERROR: No LIBRARY statement or LIBRARY parameter.
    ERROR: No LIBRARY statement or MACRO parameter.
    ERROR: Unable to open file PBPMAC.INC
    ERROR Line 12: Syntax error. (16f88.bas)
    ERROR Line 15: Bad expression. (16f88.bas)
    ERROR Line 17: Bad expression. (16f88.bas)
    ERROR Line 11: Syntax error. (Test02.bas)
    ERROR Line 12: Syntax error. (Test02.bas)
    ERROR Line 13: Syntax error. (Test02.bas)
    ERROR Line 16: Bad expression. (Test02.bas)
    ERROR Line 18: Bad expression. (Test02.bas)
    This happen only with this chip I have no prob with 16F84 or 16F877.
    Thank you for any help.
    PBP version?
    Code?
    Jun 2005
    Latest PicBasic Pro version 2.46, very simple code (even with no code at all in microcode studio). Here's a simple example I tried with :
    ANSEL = 0
    START :
    HIGH PORTB.0
    PAUSE 1000
    LOW PORTB.0
    GOTO START
    I don't think it's a programming error, more likely a compilator error. I was able to program 16F88 in the past but I format my PC recently and reinstall and now that's what I get.
    New Zealand
    I had an issue with 2.46 after I reinstalled it - slightly different to yours but give it a shot, in windows explorer go to the pbp directory and right click on pbpw.exe click on properties, then compatibility, set it to run under win 98 compatibility
    Your example compiles without error...
    PBP246>PBP -P16F88 ZTESTB -V
    PicBasic Pro Compiler 2.46, (c) 1998, 2005 microEngineering Labs, Inc.
    All Rights Reserved.
    Pass 1:
    Pass 2:
    Code Gen:
    Macro Pass:
    PM.EXE H:\DATA-R~1\PIC\PBP246\ZTESTB.ASM
    PM Assembler 4.07, Copyright (c) 1995, 2004 microEngineering Labs, Inc.
    58 words used.
    Maybe stupid but have you selected the correct microcontroller?
    Jun 2005
    OK thank you for your help. My problem seems to be a directory problem... Curiously I changed my working directory and now it works fine. Sorry for the inconvenience and thank you for helping me.
  1. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 04:14
  2. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 19:35
  3. Loop with two motor and 2 sensors
    Last Post: - 8th December 2008, 23:40
  4. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  5. 18F452 compile error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 10th November 2006, 16:56
