Mystery Compile Error
Results 1 to 16 of 16
    It's an iMac with Mac Snow Leopard OS (10.6.2). I'm using Parallels Desktop to create the Windows XP virtual machine.
    Quote Originally Posted by RossWaddell View Post
    OHHhhh...
    Well like I said, MCS and Linux do not get along and MACs are Unix based also... I think...
    I do not know the file structure of a MAC but with Linux I make a *.bat file for each project and keep it in the projects directory. At compile time I run the BAT.
    I also use GEDIT for writing code. Never got along with EMACS...
    In Linux and WINE there is a "C" directory as in windows, PBP and MPASMWIN will live there.
    Below is a BAT example. If errors are found a *.ER and a *.ERR file will be created in the projects directory. I name it "hex.bat".
    The HEX will be there also.
    Maybe something like this will work for you...
    cd /media/16GBSTIC/PIC_PROG/16f887
    wine c:/pbp/pbpw -e -s -ac:/Program\ Files/Microchip/MPASM\ Suite/MPASMWIN -p16f887 z:/media/16GBSTIC/PIC_PROG/16f887/887.bas
    wine c:/Program\ Files/Microchip/MPASM\ Suite/mpasmwin /e /l 887.asm
    Thanks Dave! I will try that tonight. If I understand your batch file correctly, then:
    - switch to the folder containing the . bas project file (I presume so the resulting .asm & .hex files will be created in the same place)
    - compile .asm file with appropriate switches to tell it what PIC you're using and what .bas file to compile
    - create .hex file
    Where could I get more info on some of the command line switches you're using?
    e.g. c:/pbp/pbpw -e -s -ac
    and mpasmwin /e /l
    Yes, everything will be in the projects directory.
    - create .hex file
    And tell the directory.
    and mpasmwin /e /l
    The PBP manual has a section about using the command line. Actually PBP is a command line program. And for the MPASWIN stuff. Open MPLAB and under Help/Topics pick MPASAM Assembler.
    Then in the index tab "Command Line Interface" sub set "Assembler".
  1. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 19:35
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  4. 18F452 compile error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 10th November 2006, 16:56
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
