different baudrate
Results 1 to 4 of 4
    Jan 2010
    Default baudrate
    i'm going to connect between 16f877 and GPS EB-85A....
    could someone help me...
    i can't run this program...
    'DEFINE HSER_RCSTA 90H
    'DEFINE HSER_TXSTA 20H
    'DEFINE HSER_BAUD 9600
    'DEFINE HSER_SPBRG 25
    DEFINE OSC 20
    include"modedefs.bas"
    pcout var portc.6 'Output to pc
    pcin var portc.7 'Input from pc
    gpsin var portb.2 'input from gps
    gpsout var portb.1 'output to gps
    gps_dat var byte
    a var byte
    for a = 0 to 41 step 1
    lookup a,["$PMTK314,1,1,1,1,1,5,1,1,1,1,1,1,0,1,1,1,1"],gps_dat
    SEROUT gpsout,T9600,[gps_dat] 'send pmtk to gps">command tok baudrate gps'
    next a
    serin gpsin,T9600,100,cont,[gps_dat]
    cont:
    SEROUT pcout,T9600,[gps_dat] 'send nmea to pc
    'serout pcout,T9600,["rt",13]
    any idea please....
    Quote Originally Posted by danial View Post
    These Defines are used With HSEROUT and HSERIN and not any other serin type commands
    DEFINE OSC 20
    gps_dat var byte
    a var byte
    What are you hoping to accomplish here? Exactly.
    next a
    What it will do is send out those characters in ASCII
    cont:
    any idea please....
    Your serout pcout will send 1 byte stored in gps_dat and then the STRING rt
    So yeah, I have some ideas, you need to explain what you want this to do and what does / does not work, and we will help you.
    Edit : didn't see the apostrophe '.
    Here is a useful link: http://www.gpsinformation.org/dale/nmea.htm#AAM
    Jan 2010
    i'm doing for my project....
    title : Positioning and navigation using GPS....
    using PIC microcontroller to interface with GPS...
    in this project i'm using Etek EB-85A module sensor...
    Does anyone hv any idea on how to do the command so that i can run the program?....
    Flow >> 1) GPS detect from satellite >>2)send data to PIC microcontroller >>
    >>3) view result at serial communicator from microCode studio.
  1. 12F629 maximun Baudrate
    By MaxG in forum Serial
    Last Post: - 28th May 2016, 06:22
  2. Serial Baudrate 115200
    By kblim in forum mel PIC BASIC Pro
    Last Post: - 9th November 2011, 19:42
  3. Hserin baudrate select
    Last Post: - 12th January 2009, 20:55
  4. 16f88 internal osc 8mhz max serial baudrate ?
    Last Post: - 17th December 2008, 00:27
  5. max baudrate serout2 command
    By mat janssen in forum mel PIC BASIC Pro
    Last Post: - 16th July 2004, 07:32
