Tiny Bootloader 18F2420
Results 1 to 12 of 12
    You can also modify the TinyB18F.asm code for other PIC types. The cool part of using PIC18 device is that you can run the bootloader WITHOUT a MAX232! Just invert your USART with RXDTP and TXCKP. I have been meaning to try it since I read this thread: http://www.picbasic.co.uk/forum/showthread.php?t=10361
    I finally tried it using a PIC18f2520 with a 22k resistor on the RX line, and with the addition of
    	BSF BAUDCON,RXDTP
    	BSF BAUDCON,TXCKP
    to the sample .asm file they call TinyB18F.asm , which is included in the Tiny Bootloader download.
    Nice to get rid of a $4.00 chip, and do it in hardware, well ... sort of software/hardware!
    And it works!!
    Dec 2009
    Default Tiny with 18F2420
    I have tiny working with the 18F252 and the 18F2420. I will upload the file in a day or so.
    scalerobotics, WOW you pay $4.00 for an MAX-232.... You must be made of money...
    Default MAX232 alternative
    No, mostly water really.
    Thanks Dave, I guess I was using a Mercedes, when I could have used a Chevy.
    A quick search of Digikey for MAX232 reveals the actual price of a Maxim MAX232 dip is $3.31 to $6.60 ( Unless you like the larger electrolytic caps). But, if you use an ST232C, instead of a MAX232, (after tax and a few capacitors), the cost is $1.25.
    Either way, you will save some money and space on your board if you invert your coms and buy two resistors.
    scalerobotics, There is just something wrong in my mind about connecting negative voltages to a unipolar input pin... I think the cost of a few transistors and a few resistors is worth the piece of mind....
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Tiny bootloader and 18F4525
    By Najim in forum Off Topic
    Last Post: - 11th January 2006, 12:43
  5. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
