Tiny Bootloader 18F2420
Results 1 to 12 of 12
    Dec 2009
    Default Tiny Boot 18F2420
    Did you ever get the tinyboot for 18F2420 working?
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by rinthesun View Post
    The original post is over 18 months old... you might not get a response !
    This is what would worry me...
    tinybld18F2420_int8MHz_19200.HEX
    Are you trying to 'reliably' load a random PIC at 19200 Baud when running an INTERNAL 8MHz Oscillator? Only in your dreams!
    Apr 2006
    GearSweaterMountain, The Netherlands
    Hi there,
    Well i did get it to work, but by using a 16F88 ....
    I could not get the tiny bl to work on the 2420, so i tried a different part to be sure it actually worked, it did work on a 16F88. Reducing the code and adding some extra analogue parts caused that i could stick to 16F88 and so i did ...
    I still have a working 16F88 tiny bootloader hex + flash the led demo for pbp.
    Let me know if you need i it ....
    Best regards,
    Ultiblade
    Dec 2009
    Default Bootloader 18F2420
    Thanks for your reply. I do have the Tiny Bootloader reliable working with a 16F886 and hoped to get it working with the 18F family. Someone must have it working from the info on the Tiny Bootloader site. I will first try it with a 18F252 and if that works try the 18F2420. If I have any luck I will post it here.
    Apr 2006
    Strange thing is that on the tiny website there is sample code called tinybld18F2420_int8MHz_19200.HEX and should work ...
    The code sample never did work. Add the fact that Melanie is talking about "in your dreams", trying first on the 252 will be a good idea.
    Succes !
    Best regards,
    UB
    You can also modify the TinyB18F.asm code for other PIC types. The cool part of using PIC18 device is that you can run the bootloader WITHOUT a MAX232! Just invert your USART with RXDTP and TXCKP. I have been meaning to try it since I read this thread: http://www.picbasic.co.uk/forum/showthread.php?t=10361
    I finally tried it using a PIC18f2520 with a 22k resistor on the RX line, and with the addition of
    	BSF BAUDCON,RXDTP
    	BSF BAUDCON,TXCKP
    to the sample .asm file they call TinyB18F.asm , which is included in the Tiny Bootloader download.
    Nice to get rid of a $4.00 chip, and do it in hardware, well ... sort of software/hardware!
    And it works!!
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Tiny bootloader and 18F4525
    By Najim in forum Off Topic
    Last Post: - 11th January 2006, 12:43
  5. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
