scalerobotics, WOW you pay $4.00 for an MAX-232.... You must be made of money...
No, mostly water really.
Thanks Dave, I guess I was using a Mercedes, when I could have used a Chevy.
A quick search of Digikey for MAX232 reveals the actual price of a Maxim MAX232 dip is $3.31 to $6.60 ( Unless you like the larger electrolytic caps). But, if you use an ST232C, instead of a MAX232, (after tax and a few capacitors), the cost is $1.25.
Either way, you will save some money and space on your board if you invert your coms and buy two resistors.
scalerobotics, There is just something wrong in my mind about connecting negative voltages to a unipolar input pin... I think the cost of a few transistors and a few resistors is worth the piece of mind....
