i cant get 18f2550 work as HID
Results 1 to 20 of 20
    Great News! And you're welcome.
    I'm not familiar with the K128 ...
    But with a quick look at the schematic in the datasheet, it seems to use a series of diodes and capacitors to increase the voltage and applies it to VPP.
    They have several different programmers.
    The LVP comment might have been directed at a different product.
    But when LVP is enabled ... anytime RB5/PGM goes HIGH ... it's just like taking MCLR/VPP to 13V.
    If it's left floating, the PIC could be constantly entering Program Mode from input noise.
    Oct 2009
    Thumbs up
    well, thats something new to learn. thx Darrel
    i m now trying to control a robtic arm using USB communication. i m reading about intruppts. i ll report my work in this thread.
    Oct 2009
    hi
    i need to know more about interrupts. when using usb communication i have to excute usbservice every milisecond or so. should interrupts help me ?
    Quote Originally Posted by Ahmadabuomar View Post
    ... i have to excute usbservice every milisecond or so. should interrupts help me ?
    They will indeed.
    Here's an include file that can do all the servicing for you in the background using the USB interrupts.
    And it adds a few handy features ...
    USB_ASM_Service.pbp
    http://www.picbasic.co.uk/forum/show...06&postcount=6
    HTH,
    Oct 2009
    hi Darrel
    thx alot for ur help. this code was very important to me.
    my problem now is that i want to control a robotic arm after i made my pc talk to my pic. the problem is that servo control in pic basic is carried by pulsout , and i should pause for 18 milisecond to complet a period.
    pulsout portb.0, period
    pause 18
    etc
    it seems that is a wrong way to do it since usbservice must be called every 1ms or so. i tried this method and it didnt work. i also tried to make a for loop like this
    for vr = 1 to 18
    pause 1
    usbservice
    next vr
    but it didnt work. is there a way to control a servo motor by a slider on my vb software? and how can i avoid pausing in pulsout ?
    Oct 2009
    hi Darrel,
    i found a good code for controlling 8 servo motors and i tried it.
    its very awsome and it contains a pc sofware too.
    unfortunatily, it is written in mokrobasic and it contains some assembly codes.
    since i m new to pic microcontrollers and i use only PBP, i didnt understand the code and its procedure.
    i wish i can understand it so i can make my own code using PBP and microcode studio. and also to programm my own vb software.
    could u explain this code and how it define 20ms periods.. etc.
    u can find attached the full folder containing pc software and also pic firmware.
    here is the code:
    program SERVO8_USB_18F2550
    '*                    18F2550 PIC USB_HID 50Hz PWM SERVO CONTROLLER                       *
    '*                     by W. Schroeder alias "xor" -- July 4, 2006                        *
    '*      Compiles with mikroBASIC 4.03 and tested on the EasyPIC3 Development Board        *
    '* Uses mikroBASIC USB_HID Library and must include "USBdsc.pbas" and "HIDconstant.pbas"  *
    '*   Also required is the free Visual Basic Servo Controller Demo program included with   *
    '*           this file. This program has been tested on Windows XP with USB2.0.           *
    '*   Configuration settings for the 18F2550 are the same as the mikroBASIC 18F2550 HID    *
    '*      example found in the mikroBASIC Examples folder in the mikroBASIC directory.      *
    '*   These configurations are set up for an 8MHz crystal oscillator and through internal  *
    '*    PLL settings this is increased to 48MHz.  This also produces a very fast 12 MIPS.   *
    '*   The EasyPIC3 board provides an easy connection to the PIC via a USB port.  Please    *
    '*        refer to the board schematic for ideas for your own circuit connections.        *
    '*       For the purposes of this demo all output pins of PORTB are utilized.             *
    '*          Servo0 is PORTB.0, Servo1 is PORTB.1, ......, Servo7 is PORTB.7               *
    '*  The range of PWM on-time is 800us to 2200us analogous with a resolution of 0 to 255   *
    '*   A value of 127/128 is considered 50% of servo rotation with an on-time of 1500us     *
    '*    Timer0 in 16-bit mode is used to establish an accurate 20ms (50Hz) PWM interval     *
    include "USBdsc"            ' this module must be included in the same folder as the main program
    dim T0 as word absolute $FD6
    dim old as byte
    dim servoport as ^byte
    dim _s0,_s1,_s2,_s3,_s4,_s5,_s6,_s7 as byte
    dim
        wrbuf    as  byte[2]
        servo    as  byte[9]
        wr_adr   as  word
    sub procedure delay_810us
      delay_us(810)
    end sub
    sub procedure interrupt
      If INTCON.TMR0IF = 1 Then                    ' if 20ms interval
        servoport^ = 255                           ' turn on all servos
        _s0 = servo[0] + 1                         ' set up temp variables
        _s1 = servo[1] + 1
        _s2 = servo[2] + 1
        _s3 = servo[3] + 1
        _s4 = servo[4] + 1
        _s5 = servo[5] + 1
        _s6 = servo[6] + 1
        _s7 = servo[7] + 1
        old = 0
        FSR0L = servoport
        FSR0H = hi(servoport)
        delay_810us                                ' this delay to hold position 0
        TMR0L = 0
        For old = 0 to 255                         ' manage 8 outputs with 256 positions each
              ASM                                  ' very efficient PWM masking routine
                 movlw     0
                 decfsz    main_global__s0, 1,0
                 iorlw     1
                 decfsz    main_global__s1, 1,0
                 iorlw     2
                 decfsz    main_global__s2, 1,0
                 iorlw     4
                 decfsz    main_global__s3, 1,0
                 iorlw     8
                 decfsz    main_global__s4, 1,0
                 iorlw     16
                 decfsz    main_global__s5, 1,0
                 iorlw     32
                 decfsz    main_global__s6, 1,0
                 iorlw     64
                 decfsz    main_global__s7, 1,0
                 iorlw     128
                 andwf     INDF0, 1,0
              END ASM
            While TMR0L = old                      ' wait until TMR0 increments
            Wend
        Next old                                   ' all outputs are off at this point
        T0= -3600                                  ' balance of time for 20ms cycle
        INTCON.TMR0IF = 0                          ' be ready to interrupt again for next interval
      Else
        HID_InterruptProc
      End If
    end sub
    sub procedure Init_Main
    	INTCON2 = 0xF5
    	INTCON3 = 0xC0
    	RCON.IPEN = 0                                ' disable Priority Levels on interrupts
    	PIE1 = 0                                     ' clear all interrupt enables
    	PIE2 = 0
    	PIR1 = 0
    	PIR2 = 0
    	ADCON1 = 15                                  ' digital IO
    	TRISA = 0
    	TRISB = 0
    	TRISC = 0
    	LATA = 0
    	LATB = 0
    	LATC = 0
    end sub
    sub procedure SERVO8_INIT(dim byref servo_port as byte,
                              dim port_config as byte)
        servoport = @servo_port + 18                          ' PORT TRIS ADDRESS
        servoport^ = servoport^ And Not(port_config)          ' SET TRIS
        servoport = servoport - 9                             ' PORT OUTPUT LATCH ADDRESS
        T0CON = %00000101                                     ' prescaler = 64 or ~5us per increment
        T0 = -4000                                            ' preset for 20ms
        INTCON = %10100000                                    ' Timer0 Interrupt Enabled and Flag Cleared
        T0CON.7 = 1                                           ' Timer0 On
    end sub
      Init_Main
      SERVO8_INIT(PORTB, 255)
      HID_Enable(@servo, @wrbuf)                              ' @servo is equivalent to the Read_Buffer
      Delay_mS(1000)
      while true
          If HID_READ <> 0 Then                               ' if USB package has arrived...servo positions are in Read_Buffer
            wrbuf[0] = 255                                    ' 255 is verification value
            HID_WRITE(@wrbuf, 1)                              ' reply to host with verification
         End If
      wend
      HID_Disable
      '** This code is necessary in order to make linker load the variables and HID_InterruptProc routine.
      '** In real time it will never execute.
      if false then
          HID_InterruptProc
          wr_adr = @DeviceDescr
          wr_adr = @ConfigDescr
          wr_adr = @InterfaceDescr
          wr_adr = @HID_Descriptor
          wr_adr = @EP1_RXDescr
          wr_adr = @EP1_TXDescr
          wr_adr = @HID_ReportDesc
          wr_adr = @LangIDDescr
          wr_adr = @ManufacturerDescr
          wr_adr = @ProductDescr
          wr_adr = @StrUnknownDescr
      end if
    end.
    I'm not familiar with MikroBasic.
    But it appears to be using Timer1 Interrupts to generate the servo signals.
    How many servos are you running?
  1. PortA Doesn't Work
    Last Post: - 8th September 2015, 18:41
  2. USB hid maker help please.
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 14:49
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  4. 18f2550 + 24lc512
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 22:02
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 12:03
