hi
yeah i did activated internal voltage regulator. he is a pic for fuse configuration in my programmer. it shows what i used
hi
You yust should set USBPPL and PPLDIV to 48MHz, or divide by 12 if you use 48MHz resonator.
I think that code is good.
Ahmadabuomar,
Another possible problem ...
According to your picture ...
Low Voltage Programming (LVP) is Enabled.
You could put a pull-down resistor on RB5/PGM, but you probably want to disable it completely since you are using the full PORTB in your program.
And pedja089, you can't use a 48Mhz resonator with the 4550's.
Maximum frequency using the main oscillator is 25Mhz.
You can use an external TTL (canned) 48Mhz oscillator with EC mode.
The top line says DEFINE OSC 48
Which seems correct from the image of the configs which shows an 8Mhz crystal with HS_PLL that gives 96Mhz.
The USBPLL is /2 so the USB gets 48Mhz, and the CPUDIV is also /2 so it's running at 48Mhz.
Except for the LVP, it all seems good.
Well, might want to disable XINST too.
thx for ur reply
i ll try to disable lvp and xinst and see what happen
brb
