12f675 making me a crazy person
Results 1 to 17 of 17
    Oct 2006
    Edmonton AB Canada
    Jerson,
    That won't work. The Chubb needs to be high or low irrespective of the Led.
    Alain,
    P&J, toast and jam, goSUB and return. Can't change one without the other. Code works like a charm. It may not be elegant, but I'm not charging myself very much for it either...
    Cheers
    Gary
    Bombay, India
    Try this for the PM assembler. If you hold Chubb high, foto1 will fire repeatedly. Release Chubb and trig will go low
    Enjoy
    @ device  INTRC_OSC_NOCLKOUT, WDT_OFF
    @ device  MCLR_OFF, PWRT_ON
    @ device  CPD_ON, PROTECT_ON
    ANSEL=%00000000
    CMCON=7
    trisio = %00000100
    ' Chubb input gpio.5
    ' Output to panel - Trig var gpio.2
    ' Photo Guy gpio.4
    input gpio.5
        Chubb var gpio.5
    output gpio.4
        Led var gpio.4
        low led
    output gpio.2
        Trig var gpio.2
        low trig
    'Variable for the photo guy
    x var word
        x = 10
    ' Test the photo guy
    PAUSE 2000
        HIGH LED
            PAUSE 250
        LOW LED
            PAUSE 250
        HIGH LED
            PAUSE 250
        LOW LED
    PAUSE 2000
    'start here
    loop:
        if Chubb = 0 then
            high trig
            if X < 11 then
                X = 12
                gosub cola
            low trig
        if x > 11 then
            x = (x + 1)
        if x >= 300 then
            x = 10
        if x = 100 then
            GOTO foto1
    goto loop
    foto1:
        high led
        low led
                pause 250
        high led
        low led
    goto loop
    cola:
        high led
        low led
    Wink
    Quote Originally Posted by Meriachee View Post
    Code works like a charm.Gary
    Hi, Gary
    I did understand it was the reason for you to show it here ... sure !
    So you have it all figured out now? What did you do to fix it?
    Oct 2006
    Edmonton AB Canada
    There was a goto a subroutine, and a return at the end of it. Funny how PBP doesn't understand that it was s'posta go back to where we left off.
    The panel got installed this afternoon, and after a small expected timing change to the photoguy, it works like a charm.
    Thanks for all the help.
    Gary
  1. 12F683 vs 12F675.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 11th July 2009, 05:58
  2. Instant Interupts with a 12f675
    By wlundonly in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 02:52
  3. 12F675 won't reprogram or erase
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 06:07
  4. 12f675 serial pic2pic
    By tagan in forum mel PIC BASIC Pro
    Last Post: - 12th March 2006, 23:55
  5. Multitasking 12F675 I/O
    By jpeakall in forum mel PIC BASIC Pro
    Last Post: - 26th November 2003, 01:57
