The RS485 chip hasnt been plugged in most of the time
For most of this testing the RS485 chip hasnt been plugged in and the data wires disconnected. When it has been connected up the RS232 to RS485 convertor has been running from the same power supply.
Im pretty sure theres no problem with the RS485 part of the circuit. When the chip starts having a fit during pause commands if i pull the 555 out then it suddenly goes back to normal.
I also tried using the 555 on the breadboard but removing its regulator and connecting the power wires after the regulator on the PCB and that causes problems aswell. It only works when the 555 and PIC have different regulators
