PIC stop responding - Strange Problem!
Results 1 to 9 of 9
    Bombay, India
    The leds are shown the wrong way. If this is how you have them connected, they will not light up. But, this is a minor issue
    Check your power supply. Remove the PIC and force both relays to on via jumpers. In this condition, what is the supply voltage to the input/output of the 78L05? Is the PIC Vdd being satisfied?
    You do not have a decoupling cap across the PIC Vdd-Vss.
    +1 for Jerson ...
    AND, once more
    Do not forget the .1or .22 µF cer capacitor as close as possible to the power pins ( 1-8 ) s
    a 10µF tantalum at the 78L05 output won't be too much nor ...
    instead of the Diode across relay coil terminals, a series RC really goes fine ... but some scope necessary to tune the values ... leaves the power lines much cleaner !
    Question
    Thanks for thr reply Jerson. After I switch all 4 relays on, 78L05 input/output is left with 10.9V, still having 5V for PIC.
    Should I increase the resistance for the LEDs as well?
    May 2008
    Italy
    Tray adding the two capacitors and one diode as per the attached schematics.
    It should cure the problem.
    Al.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. strange serout2 problem
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 7th January 2010, 10:33
  3. PIC HSERIN problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 20th July 2008, 12:08
  4. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 21:45
