Button command question
Results 1 to 10 of 10
    Jul 2009
    Default Button command question
    I am using the 5 button commands to handle 5 push buttons in my application. No auto repeat is used, just a simple if pressed… then do… My software checks on each button in order or importance, and once it finds that one is pressed, it jumps out of the 5 button sequence and performs the necessary task. All this works very well.
    Now my client requests that when 2 buttons are pressed simultaneously, something else is done. Can any one point me in the right direction to check for two of them pressed at once?
    Hello aherrera,
    Ok suppose you are using PortB as follows
    'PortB.0 = switch 1
    'PortB.1 = switch 2
    'PortB.2 = switch 3
    'PortB.3 = switch 4
    'PortB.4 = switch 5
    and you are doing If PortB.0 = 1 then . . .
    the port has a binary value when you push a switch, port B.0 = 1, portB.1 = 2, both = 3
    so you could use a select case statement or a lookup table to direct your code flow.
    Jul 2009
    I am not checking every pin; I am using the button command so I can de-bounce the switches.
    Quote Originally Posted by aherrera View Post
    Ok button command is overrated and too complicated.
    i am not home and do not have the manual with me so bear with me if I error.
    myVar var byte[5]
    myVar.0 = portB.0
    myVar.1 = portB.1
    myvar.2 = portB.2
    myvar.3 = portB.3
    myvar.4 = portB.4
    check:
    if myVar != 0 then pause 50
    if myVar != 0 then
    select case myvar
    case 0 goto check
    case1  ' button1 pushed
    do something . . . fish
    case2   ' button2 pushed
    do something . . .cut bait
    case3 ' 2 buttons pushed
    do another something . . . look for better lake
    case 4 ' button3 pushed
    case 7 ' 3 buttons pushed
    do or not do you decide
    case else
     goto check
    end select
    goto check
    some of the syntax may be incorrect above but it should steer you to what you are wanting
    Jul 2009
    Thank you for your help, so, you think is over rated, I see you are de-bouncing by pausing, but this will cause the software to repeat the press if someone holds the button pressed, the button command takes care of all this.
    Another idea.. sort of.
    I do not think it is likely that two buttons will be pressed at the same time. So if the buttons are on the same port then read the port twice to see if the second one has been pushed.
    Untested but something like
    CHECK_BUTS:
    BUTVAR = PORTB & $1F
    IF BUTVAR >= 1 THEN CHECK2
    GOTO CHECK_BUTS
    CHECK2
    PAUSE 50
    SELECT CASE BUTVAR
    'insert case statements
    GOTO CHECK_BUTS
    Wink BUTTON is really fine ...
    BUTTON Command could be fine here ... let's suppose button tie pin to ground.
    SCAN:
    FOR I = 0 to 4
       BVar = 0
       BUTTON PORTB.0[I],0,255,0,BVar,1,Action
    NEXT I
    I =  255 ' just to allow CASE 0 ...
    Action :
    SELECT CASE I
        CASE 0 ...
        CASE ELSE  GOTO SCAN
    END SELECT
    As the debouncing do not occur if button is not pressed ( Mr de la Pallice )... scanning is very fast !
    CQFD
    Wink With 2 buttons now ...
    For twin Button press ...
    just add another scan loop ...
    SCAN:
    RESULT = 0
    FOR I = 0 to 4
       BVar = 0
    NEXT I
    GOTO SCAN                                             ' No need to go further ...
    Action :
          RESULT.I = 1                                     ' Store the first button pushed
          PAUSE 250                                         ' Let a little time for pushing the
        ' next button ...
          FOR J= 0 to 4
          IF J = I THEN I = I+1                            ' Button already pushed !!! ... Skip test.
          BVar = 0
         BUTTON PORTB.0[I],0,255,0,BVar,1,Action2
         NEXT J
         GOTO Action1                                       ' Only one button Pushed  ...
    Action2:
    RESULT.J = 1                                              ' Store the second button pushed
    Action1:
    SELECT CASE RESULT
        CASE %00000001                      ' Button 0 alone
        CASE %00000010                      ' Button 1 Alone
        CASE %00000100                      ' Button 2 Alone
        CASE %00000011                      ' Buttons 0 and 1 ... or  1 and 0
        CASE %00000101                      ' Buttons 0 and 2 ... or  2 and 0
        CASE %00000110                      ' Buttons 1 and 2 ... or  2 and 1
        CASE %00001010                      ' Buttons 1 and 3 ... or  3 and 1
        CASE %00001100                     ' Buttons 2 and 3 ... or  3 and 2
        CASE %00010100                     ' Buttons 2 and 4 ... or  4 and 2
        CASE ELSE  GOTO SCAN
    END SELECT
    with 16 bits for RESULT, RESULT.Highbyte for I, RESULT.Lowbyte for J, .... you can even check in which order the buttons have been pushed ...
    Too much ??? Ok, I take it back to my kangaroo pocket ...
    Jul 2009
    I want to thank everybody for their great help. I think I have enough to get me going here...
    Exclamation
    Arrrgh !!!
    a little typing bug :
    should have been
       IF J = I THEN J = J+1                            ' Button already pushed !!! ... Skip
    as everybody did notice ...
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 17:44
