Instant Interrupts - Revisited
Results 1 to 40 of 773
    Hi, Darrel,
    I Ported it to MCS ...
    ERROR : MACRO BUFFER OVERFLOW ...
    Which looks sililar to the error MPASM raised.
    Lightbulb
    HI,Darrel,
    a special character compiler do not like ???
    That error only happens when compiling with PM.
    Switch to MPASM for an 18F452.
    Normally it will warn you when compiling 18F programs with PM.exe. But I think the macro overflow causes too many errors before it gets to that warning, so you don't see it in MCS.
    Ooooops, sorry.
    Compiled fine in MCS ...
    Great mistery ... for sure !!!
    Unhappy
    Result is the same with " T-Elapsed_18" ... straight out of the Package ...
    Executing: "C:\Program Files\Microchip\MPLAB IDE\PBP\PBPMPLAB.BAT" -ampasmwin -k# -p18F452 "T_Elapsed-18.bas"
    Executing: "C:\Program Files\Microchip\MPLAB IDE\PBP\PBPW.EXE" -ampasmwin -k# -p18F452 "T_Elapsed-18.bas"
    PICBASIC PRO(TM) Compiler 2.60, (c) 1998, 2009 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to execute mpasmwin.Message[301] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PBP\18F452.INC 23 : MESSAGE: ( PENSEZ à INDIQUER la BONNE CONFIGURATION ... )
    Message[301] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PBP\18F452.INC 24 : MESSAGE: ( PENSEZ à INDIQUER la BONNE CONFIGURATION ... )
    Error[116] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\T_ELAPSED-18.ASM 609 : Address label duplicated or different in second pass (Z00022)
    Error[116] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\T_ELAPSED-18.ASM 672 : Address label duplicated or different in second pass (Z00023)
    Error[116] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\T_ELAPSED-18.ASM 725 : Address label duplicated or different in second pass (Z00024)
    Error[116] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\T_ELAPSED-18.ASM 756 : Address label duplicated or different in second pass (Z00025)
    Halting build on first failure as requested.
    BUILD FAILED: Fri Aug 21 12:08:46 2009
    Lightbulb
    Strange thing ...
    DT 14 bits interrupts Examples Compile fine ( With MPLAB ), but NOT 16 bits interrupts Examples ...
    No wonder I don't like MPLAB.
    The problem seems to have something to do with the -k# command line option. (new option for pbp2.60)
    If I use the same batch file that MPLAB uses ... PBPMPLAB.BAT
    Then this command gives me the same errors you reported.
    c:\PIC\PBP260\PBPMPLAB.BAT -ampasmwin -k# -p18F452 "Tracteur.bas"
    If I remove the -k# option it compiles fine.
    I haven't found a way to remove it from within MPLAB.
    And I think if you did, you wouldn't be able to debug in MPLAB.
    Added: In the PBP manual it only shows -k- and -k+. -k# doesn't even seem to be a valid option.
    Not that it matters much, because it fails with either -k- or -k+ too.
    Lightbulb Oh ok!
    I see exactly what's happening now.
    This is one for meLabs to solve.
    In an attempt to produce the COFF information for debugging with MPLAB, ... PBP with the -k option places Z????? Labels on every line of code ... including the "ASM" or @ lines.
    If the program has any ASM macros in it (like DT_INTS), you can normally jump in and out of ASM anytime you need to within that macro.
    But with it putting labels at the "ASM" statements, ... when those macros get used (more than once) it duplicates labels that were not in the original program.
    For instance with this macro ...
    MyMacro  macro
       ; asm statements here
       ; PBP statements here
      ASM  ; This statement creates a label in the middle of a macro.
    @ MyMacro  ; The first time it's used is OK
    @ MyMacro  ; the second time or more duplicates that label
    I'll send a report to support at melabs.com
    Unhappy
    Hi darrel ...
    YES ... but BUILD fails ... no HEX generated, halas.
    Bouhouuuuu ...
    Unhappy
    I've been wondering what it would take...or if anyone has managed to change the Timereload (External Constant), to a variable that can be altered in the main program...
    Actually, I would like to load this value from eeprom on startup, but I am at a loss for how to go about this short of learning asm...
    ;---Reload Timer1------ (T1 asm interrupt handler)
    ReloadTMR1
    MOVE?CT 0, T1CON, TMR1ON ; 1 stop timer
    MOVLW LOW(TimerReload) ; 1 Add TimerReload to the
    ADDWF TMR1L,F ; 1 value in Timer1
    BTFSC STATUS,C ; 1/2
    INCF TMR1H,F ; 1
    MOVLW HIGH(TimerReload) ; 1
    ADDWF TMR1H,F ; 1
    MOVE?CT 1, T1CON, TMR1ON ; 1 start timer
    INT_RETURN
    Quote Originally Posted by Michael Wakileh View Post
    ReloadTMR1
        INCF     TMR1H,F              ;  1
        ADDWF    TMR1H,F              ;  1
      INT_RETURN
    I'm sure there are a number of ways to do it, but a direct translation of that routine might look like this ...
    TimerReload VAR WORD BANK0
    ReloadTMR1
        MOVF     _TimerReload,w       ;  1     Add TimerReload to the
        INCF     TMR1H,F              ;  1
        MOVF     _TimerReload + 1,w   ;  1
        ADDWF    TMR1H,F              ;  1
      INT_RETURN
    Then TimerReload is a PBP word variable.
    You can calculate it or read it from EEPROM as desired.
    Smile IOC handler
    Thanks Darrel! works great!
    I've been experimenting with the interrupt system lately and although its not relevant for my purposes, I noticed something I can't explain...
    I'm guessing it has something to do with the port variables saved...
    I have a pic12f683
    Led1 GPIO.1 toggled by 1Hz Timer1 interrupt (...in my case via external crystal)
    Led2 GPIO.2 toggled by IOC/RB interrupt.
    The RB interrupt also starts or stops the timer...allowing for control of the blinking LED1. This part works however LED2 only turns off briefly when the button is pressed.
    Things work normal if a flag bit is "toggled" and the Leds are controlled in the main program...
    RBPortIntPBP:
    'toggle gpio.2
    if T1CON.0 = 0 then
    TOGGLEFLAG = 1              'attempt doing this via main handler
    TOGGLEFLAG = 0
    pause 300
    @ INT_RETURN
    Can anyone explain, and is there away to do this from within the handler?
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 6
