I find it.....
Now it sleeps with the minimum current...just 0.1 ma or 100uA.
The pin MCLR was flatting and I add the 4.7k to Vcc.
Many Many thanks joe for your code.
Nikos
I find it.....
Nikos
Just looking at your code and decided to ask a question or two.
Why do you set the same configs twice? I think either will accomplish the task but they may be contradictory also.
Why are some configs spelled differently from one to the other? PWRT/PWRTE, INTRC_OSC_NOCLOCKOUT/INTOSC_OSC_NOCLKOUT and MCLR/MCLRE are the ones I see as different.
Which code is that exactly? I'm sort of guessing here so if I'm referring to the wrong one please disregard this.Just looking at your code and decided to ask a question or two
The only code in this thread, which could be interpreted as if that's happening is in the third post, by Archangel, but he's not setting the same config twice. One set is commented out:Why do you set the same configs twice?Code:;@ DEVICE PIC16F648A, INTRC_OSC_NOCLOCKOUT ;@ DEVICE pic16F648A, WDT_OFF ;@ DEVICE pic16F648A, PWRT_ON ;@ DEVICE pic16F648A, MCLR_OFF ;@ DEVICE pic16F648A, BOD_OFF ;@ DEVICE pic16F648A, LVP_OFF ;@ DEVICE pic16F648A, CPD_OFF ;@ DEVICE pic16F648A, PROTECT_OFF @ __CONFIG _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _LVP_OFF & _BODEN_OFF & _BOREN_OFFMy guess is that one set (the ones that are commented out) is/was targeting the now obsolete PM-assembler which came bundled with PBP while the other is for Microchips MPASM assembler.Why are some configs spelled differently from one to the other? PWRT/PWRTE, INTRC_OSC_NOCLOCKOUT/INTOSC_OSC_NOCLKOUT and MCLR/MCLRE are the ones I see as different.
My bad. I sincerely apologize for any confusion I might have generated. In the future I'll cut and paste the code to which what I refer to eliminate any obfuscation.
Sorry for using your time but thanks for a possible explanation and pointing out my error.
