I have working code for 14bit 610hz BAM with 16 output PWM channels (code could be updated to get more channels with external logic if needed), but i didn't tried to resolve flicker problem with BAM yet. I think that simple signal mirroring doesn't help to fully avoid flicker(s), it just makes it significantly lower, but maybe also affects visual perception of signal "decreasing" actual refresh rate. And there are other ways to avoid flicker trouble, too. However, MIBAM is very good approach, thanx to it's simplicity in combination with reasonable effectivity. Thank You, Darrel Taylor & RadikalQ3 for giving good explanations and usefull thoughts. Btw, additional advantage of MIBAM method is that it might slightly reduce level of generated EMI.
It's amazing how many people have come here to tell me that the Mirror Image won't fix BAM's blinking problem.
With the mirror image, there is absolutely NO blinking AT ALL. (Not even with a video camera).
Of course everyone admits that they've never even tried it.
But yet they still feel it's ok to tell the world that it won't work.
All I can do is return the favor ...
16 channel, 14-bit BAM, at 610hz, with a PIC, is IMPOSSIBLE.
It was bad enough when you said 13-bit. But now with 14-bits, the minimum period would be 0.1 µS. There's NO WAY you can set 16 outputs to the desired states with only one instruction, then set them all to new states on the very next instruction.
But then ... "I've never tried it".
Sorry for my poor english, maybe u hadn't understood me as it was supposed. I don't want to flame here... i feel a bit tired myself and i'm way too lazy now to start explanation again. I had thought to upload code here, but now i'm not sure of your reaction. Maybe even then u gonna blame me). Just read my previous posts again. But i don't want to disappoint u and u a free to think that i'm lousy liar))) Actually i started to code in ASM 17 years ago. And i don't have to prove nothing here. Yes, it works. Yes i didn't tried MIBAM yet with _MY_ 14 bit _BAM_ code (which was written about half year ago). I work periodically for local advertising companies and earn some $$$ from things i develop using my older 13 bit code for 18F, which actually isn't BAM nor "clear" PWM. (which, btw could also be upgraded to 14 bit 610Hz, but don't ask me how, as i had already described it). Sorry, do not have enough strength to continue that, i feel myself wasted a bit 8] best regards....
I'm sorry you're so tired, and I wouldn't want you to waist any more of your time.... Yes i didn't tried MIBAM yet with _MY_ 14 bit _BAM_ code (which was written about half year ago). ...
I'm sure trying to explain something that's IMPOSSIBLE would really take a lot out of you.
But if it makes it any easier for you ... I don't need to see your whole code, or have a big explanation with pictures and billboards.
But I would like to know how you got past this one single problem.
Since you do ASM, it's only 2 lines of code.Originally Posted by Darrel Taylor
I would be apologizing profusely for weeks to come if you could.
