RX TX modules - intermitent communication
Results 1 to 14 of 14
    Thanks dhouston,
    The Serin/Serout version looks good thanks
    I understand your explanation for the Pulsout.
    If i understood correctly... the problem is for the RX module distinguish the Data from noise, correct ?
    Since the RX module will "see" the data transmition with the pulsout trick and grab it, after processing internally, it should give the message correctly to the pic.
    Then why the Receiver pic needs to "Pulsin" the RX module?
    I'm looking forward to test the SerIn version tonight
    Dec 2005
    Quote Originally Posted by ruijc View Post
    In effect, the receiver code waits for a pulse of sufficient length then calls SerIn2 to catch the message that follows the intervening space. IOW, the pulse is seen as a "start of transmission" marker by the receiver
    Thanks for your time dhouston.
    I've tryed the Serin2/Serout2 version but i couldn't receive any message
    Since my modules work at 19200 i changed the code like ( the rest is the same as you posted ):
    TX
    SerOut2 tx,16416,["HELLO",10]
    RX
    SerIn2 rx,16416,[STR msg\5\10]
    lcdout cl,row4, "received - ",STR msg\5
    Dec 2005
    I guess I should have looked at the datasheet for your modules but, based on your code in the first post, assumed they are ASK - they are FSK which changes things a bit. See Data Reception on p5 of the link you gave.
    Dec 2005
    Since this is an FSK module that automatically outputs any valid RF input, there is no need for a sync pulse (or sync byte such as $55). However, you really need the first bit of each reception to trigger an interrupt to assure that you catch each byte. I haven't tried to keep up with the threads on Darrel's Instant Interrupts but you might find some example code there that will help you. Here's a link to an assembly language tutorial on interrupt driven RS-232 on a PIC. http://www.winpicprog.co.uk/pic_tutorial7.htm
    The simplest route might be to use an MCU that has interrupt driven RS-232 built in. The ZX-328n (28 pins) from ZBasic <http://www.zbasic.net/> has a hardware UART as well as interrupt driven software UARTs (up to four, depending on speed - since you need 19200, it can only support one). It will handle all of this in the background, buffering the inputs automatically so that you do not miss any should they occur while your code is busy with something else.
    The ZX-328n costs $10 although shipping cost may be significant if shipped outside the USA. The ZBasic compiler is free so the only additional cost is for a crystal and the components needed for the main RS232 interface (e.g. MAX232) needed for downloading the application code.
    Since your modules are transceivers, another approach would be for the 'receiver' to send a signal to the 'transmitter' telling it to send the data. That way it doesn't arrive at random times.
    Hi dhouston,
    You are correct, these are FSK modules and they output automatically the data, that's why i had those questions made about the pulsin
    True, but in this case i'm starting with a very simple Loop ( both RX and TX ). For now i'm not thinking Interrupts. Just need to get the data flowing correctly first and therefor i'm using just this :
    TX
    tx:
    debug "ok", dec value dig 3, dec value dig 2, dec value dig 1, dec value dig 0
    gosub getvalue
    goto tx:
    RX
    rec:
    debugin [wait ("ok"),dec4 MYDATA]
    lcdout cl,row4, "received - ",DEC MYDATA
    goto REC
    Still, i get the same simptoms...sometimes receive all digits, sometimes none, sometimes just one or two
    Thanks again for all your help.
    Dec 2005
    The $55 in your original code led me to think ASK. Using a pulse is better than $55 or $AA as sync bytes.
    You will miss data that arrives while you are servicing the LCD. Another possibility is that the RF signal strength is marginal. leading to sporadic reception.
  1. Replies: 67
    Last Post: - 8th December 2009, 02:27
  2. RX - TX timming
    Last Post: - 12th February 2009, 00:06
  3. RX / TX duo
    By mbw123 in forum General
    Last Post: - 30th July 2006, 16:07
  4. TX RX Buffer Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 14th January 2005, 01:49
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 14:55
