RX TX modules - intermitent communication
Results 1 to 14 of 14
    Post RX TX modules - intermitent communication
    Hi guys,
    I'm starting to play with Rx/Tx modules.
    I've bought a couple of Cy2198TR-a modules ( http://www.sure-electronics.net/rf,audio/GP-GC010.pdf ) and connected them to a couple of 16F88 pics.
    I was able to communicate from pic to module, choose the channel and when transmitting/receiving i can see the Busy led on on both of them.
    The transmitter is sending a simple message ( a 4 digit value ) every second.
    The problem is the receiver side.
    Sometimes skips messages, sometimes shows the entire message ( 4 digit value ), sometimes shows just on or two digits of the message.
    Here is the code for the RX and TX:
    RX
        CCP1CON = %00000000         ' Disable CCP
        SSPCON.5 = 0                ' Disable SSP Module
        CMCON = %00000111           ' comparator off
    TRISA=%00010001
    TRISB=%00000111
    'DEFINEs
    @ DEVICE PIC16F88, HS_OSC
    @ DEVICE PIC16F88, MCLR_OFF
    @ DEVICE PIC16F88, PROTECT_OFF
    DEFINE OSC 8
    @ DEVICE PIC16F88, CPD_OFF
    @ DEVICE PIC16F88, LVP_OFF
    @ DEVICE PIC16F88, BOD_OFF
    @ DEVICE PIC16F88, PWRT_OFF
    @ DEVICE PIC16F88, WDT_OFF
    @ DEVICE PIC16F88, CCPMX_OFF
    'ADC
    DEFINE ADC_BITS 10 ' Set number of bits in result ( 8 or 10 bits )
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    ANSEL=%00000001
    ADCON1=%10000000 'no Vref - Right Justify
    ADCON0=%11000001
    ' DEFINE LCD pins
    DEFINE  LCD_DREG        PORTB
    DEFINE  LCD_DBIT            4
    DEFINE  LCD_RSREG       PORTA
    DEFINE  LCD_RSBIT           3
    DEFINE  LCD_EREG        PORTA
    DEFINE  LCD_EBIT            2
    DEFINE  LCD_BITS            4
    DEFINE LCD_LINES 4
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    'debug defines
    INCLUDE "modedefs.bas"
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_BAUD 19200
    DEFINE DEBUG_MODE 1
    DEFINE DEBUGIN_REG PORTB
    DEFINE DEBUGIN_BIT 2
    DEFINE DEBUGIN_BAUD 19200
    DEFINE DEBUGIN_MODE 1
    'PINS
    adc     var          PORTA.0  'analog input
    in      var          PORTA.1  'n/a
    A2      var          porta.2  'lcd
    A3      var          porta.3  'lcd
    A4      var          porta.4  'n/a
    pgm     var          porta.5  'n/a
    RsBit   var          porta.6  'xtal
    EBit    var          porta.7  'xtal
    BUT1    var          portb.0  'button
    stat    var          portb.1  'reserved for buSY
    led2    var 	     PORTB.2  ' in
    nc      var 	     PORTB.3  ' out
    lcd4    var          portb.4  'Data pin for LCD
    lcd5    var          portb.5  'Data pin for LCD
    lcd6    var          portb.6  'Data pin for LCD
    lcd7    var          portb.7  'Data pin for LCD
    'variables
    media    var        WORD	'average
    ME       var        WORD	'
    ps4      var        WORD	'
    value    var        WORD	'value received
    ra       var        word
    MYDATA   var        word
    'contants
    Row1  CON 128 'constant for LCD line1
    Row2  CON 192 'constant for LCD line2
    Row3  CON 148 'comstant for LCD line3
    Row4  CON 212 'constant for LCD line4
    cl    con 254 'constant for LCD clear line
    clear
    INCLUDE "lcdbarIN.bas"
    DEFINE  LCD4X20  1
    INIT:
    pause 400
    lcdout $fe,1,"  TX demo "
    lcdout $fe,$c0,"     ...        "
    pause 1500
    debug $55
    if but1=1 then
    goto chann
    man:
    high pgm
    me=0
    for ra=0 to 15
    adcin adc,value
    pause 50
    me=me+value
    next ra
    me=me/16
    media=me
    media=(media*/5000)>>2
    lcdout cl,row1," adc ", dec value
    lcdout cl,row2," average  ", dec media
    transmit:
    lcdout cl,row4,"transmiting - ",dec value ,"   "'change B1 for B2
    debug $55,"ok", dec value dig 3, dec value dig 2, dec value dig 1, dec value dig 0
    goto man
    chann:
    low pgm
    pause 50
    while but1=1
    debug $af, $00
    wend
    goto man
    and the RX
        ANSEL = %00000000           ' digital mode
    TRISA=%00111100
    TRISB=%00000111
    'DEFINEs
    DEFINE OSC 8
    ' DEFINE LCD pins
    DEFINE  LCD_DBIT            4
    DEFINE  LCD_RSBIT           1
    DEFINE  LCD_EBIT            0
    DEFINE  LCD_BITS            4
    DEFINE LCD_LINES 4
    'debug defines
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_MODE 1
    'PINS
    a1      var          PORTA.0  'lcd
    a2      var          PORTA.1  'lcd
    led     var          porta.2  'n/a
    A3      var          porta.3  'n/a
    A4      var          porta.4  'n/a
    pgm     var          porta.5  'frequency
    BUT1    var          portb.0  'button1
    'variables
    ME       var        WORD	'
    ps4      var        WORD	'
    value    var        WORD	'
    ra       var        word
    MYDATA   var        word
    'contants
    clear
    DEFINE  LCD4X20  1
    INIT:
    pause 400
    lcdout $fe,1,"  RX demo "
    pause 1500
    if but1=1 then
    goto chann
    man:
    high pgm
    me=0
    lcdout cl,row2," media  ", dec media
    rec:
    debugin [wait ("ok"),dec4 MYDATA]
    lcdout cl,row4,"                    "
    lcdout cl,row3,"                    "
    lcdout cl,row4, "received - ",DEC MYDATA
    goto REC
    chann:
    low pgm
    pause 50
    while but1=1
    debug $af, $00
    wend
    goto man
    Any ideas for this to occur ?
    I thank in advance
    Dec 2005
    Greetings dhouston,
    thanks for the help!
    I read your article and the Demo code.
    To be honest i didn't understood some of the lines in the code and a bit of the article( being English as NOT my native language and just starting to learn comm/protocols and stuff...doesn't help ).
    In your demo code you use Pulsin instead of Debugin or Serin and this makes me get confused.
    I was looking for a simple approach where i could use the debugin/HSerin instructions.
    Is there any other way for this to work ?
    Dec 2005
    @ruijc
    I have added examples that use SerOut2 and SerIn2 but I have not tested these as I'm rather busy with a project of my own right now. They should be easier to follow.
    The problem with using $55 or $AA (or a string of several) is that the receiver has difficulty distinguishing them from the normal noise it sees in the absence of a signal. Using a long pulse followed by a space (about half the length of the pulse) sets the receiver AGC and gives the receiver an easy to distinguish marker for the start of a transmission. Keeping communications packets short will help maintain DC balance
    Thanks dhouston,
    The Serin/Serout version looks good thanks
    I understand your explanation for the Pulsout.
    If i understood correctly... the problem is for the RX module distinguish the Data from noise, correct ?
    Since the RX module will "see" the data transmition with the pulsout trick and grab it, after processing internally, it should give the message correctly to the pic.
    Then why the Receiver pic needs to "Pulsin" the RX module?
    I'm looking forward to test the SerIn version tonight
    Dec 2005
    Quote Originally Posted by ruijc View Post
    In effect, the receiver code waits for a pulse of sufficient length then calls SerIn2 to catch the message that follows the intervening space. IOW, the pulse is seen as a "start of transmission" marker by the receiver
  1. Replies: 67
    Last Post: - 8th December 2009, 02:27
  2. RX - TX timming
    Last Post: - 12th February 2009, 00:06
  3. RX / TX duo
    By mbw123 in forum General
    Last Post: - 30th July 2006, 16:07
  4. TX RX Buffer Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 14th January 2005, 01:49
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 14:55
