Simple Array Demo
Results 1 to 6 of 6
    Default Simple Array Demo
    Hello,
    this little example just cycles through a 26 element array and displays it's value. I wrote it to
    teach myself array function, and with help from Jerson it works as expected. I am posting it here to assist noobies trying to grasp array function.
    '*  Name    : ARRAY DEMO.BAS                                    *
    '*  Author  : Joe S. with Thanks to Jerson in Bombay            *
    '*  Notice  : Copyright (c) Joe S.                              *
    '*          : No Rights Reserved, Use as you see fit            *
    '*  Date    : 5/21/08                                           *
    '*  Notes   :Demo Array Counter reads array 1 BYTE at a time    *
    '*           and displays serially on backpack LCD              *
    '*          :PBP VER 2.50                                       *
    'DEMONSTRATES USE OF FOR NEXT LOOP TO READ ARRAY                *                                   *
    'THIS PROGRAM PROVES SERIN AND SERIN2 WILL WORK ON THE SAME PIN *
    'WITHIN A SINGLE PROGRAM. DEMONSTRATES USE OF STR FUNCTION WITH *
    'SERIN2.COMPILE WITH MPASM ASSEMBLER.COMPILES TO 419 WORDS IN   *
    '16F628A                                                        *
    @ __config  _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF  & _BODEN_OFF
    DEFINE OSC 20
    include "modedefs.bas"
    LETTERS VAR BYTE ' VARIABLE TO HOLD CHARACTERS IN F/N LOOP
    CHAR var byte[26]' ARRAY VARIABLE NAMED CHAR 26 ELEMENTS
    serout PortB.6,T9600,[254,128,"ARRAY DEMO"]   ' SHOW US YOU ARE ALIVE
    pause 500        ' TIME TO VIEW LCD SPLASH STATEMENT
    serout PortB.6,T9600,[$FE,1]'CLEAR LCD PRIOR TO WRITING
    '* * * * * * LOAD ARRAY WITH STRING VALUE
    CHAR[0]= "A"
    CHAR[1]= "B"
    CHAR[2]= "C"
    CHAR[3]= "D"
    CHAR[4]= "E"
    CHAR[5]= "F"
    CHAR[6]= "G"
    CHAR[7]= "H"
    CHAR[8]= "I"
    CHAR[9]= "J"
    CHAR[10]="K"
    CHAR[11]="L"
    CHAR[12]="M"
    CHAR[13]="N"
    CHAR[14]="O"
    CHAR[15]="P"
    CHAR[16]="Q"
    CHAR[17]="R"
    CHAR[18]="S"
    CHAR[19]="T"
    CHAR[20]="U"
    CHAR[21]="V"
    CHAR[22]="W"
    CHAR[23]="X"
    CHAR[24]="Y"
    CHAR[25]="Z"
    '* * * * * * * DISPLAY ARRAY ELEMENTS VALUES SEQUENTIALY
    loop:
         FOR LETTERS = 0 to 25 'CYCLE FROM A TO Z
         serout PortB.6,T9600,[254,128,"CHAR is ",(CHAR[LETTERS])]
         pause 500            'TIME TO VIEW LETTER
    NEXT LETTERS
         FOR LETTERS=25 TO 0 STEP -1 'CYCLE  THEM IN REVERSE Z TO A
         PAUSE 500 ' TIME TO VIEW LETTERS
    NEXT LETTERS
         PAUSE 500 'TIME TO VIEW LAST LETTER
    goto LOOP2
    '* * * * * * * * * * DISPLAY ENTIRE ARRAY VALUE AT ONCE
    LOOP2:
          serout2 portb.6,84,[$FE,1]     'CLEAR LCD PRIOR TO WRITING TO IT
          PAUSE 50     'TIME FOR LCD TO SETTLE, DROPS 4 CHARS WITHOUT THIS
          serout2 PortB.6,84,10,[str char\26]
    '     PACE 10 ALLOWS SEROUT2 TO QUICKLY WRITE ARRAY'S FULL VALUE TO LCD
          pause 2000 ' TIME TO VIEW FULL ARRAY'S CONTENT
          serout2 portb.6,84,100,[$FE,1] 'CLEAR LCD BEFORE LOOP
    goto loop
    I realise there are likely easier ways to load the ARRAY . . .Baby Steps
    Anyone wishing to post more or better examples of ARRAY functions are invited to do so on this post.
    Thank You,
    JS
    Last edited by Archangel; - 10th April 2011 at 04:16. Reason: make code more readable.
    Default Array and external EEPROM Demo
    Still playing with and learning about arrays, mostly by trying to solve newbies problems. Here is a demo to write to and read from a 24LC01B I2C EEPROM using a 12F675. It outputs to a serial LCD.
    ' I2CREAD and I2WRITE Commands with External EEPROM on 12-bit core
    ' Write to the first 36 locations of External I2C EEPROM
    ' Read from eeprom and output sequentaly then as strings
    ' Tested on 12F675  using 24LC01B EEPROM
    @ __config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _WDT_ON & _MCLRE_ON & _CP_OFF & _BODEN_OFF
    DEFINE DEBUG_REG	GPIO
    DEFINE DEBUG_BIT	2
    DEFINE DEBUGIN_BIT	5
    DEFINE DEBUG_BAUD	2400
    DEFINE DEBUG_MODE	0
    DEFINE SHIFT_PAUSEUS 1000
    EECON1   = 7  'Probably not needed here, enables internal eeprom
    CMCON    = 7  'Disable comparators
    ADCON0.0 = 0  'Disable A/D converters
    ANSEL    = 0  'Disables Analog Select
    DPIN var GPIO.0   'Assign Data pin
    CPIN var GPIO.1   'Assign Clock pin
                ' a nice place to store things
    B0 var byte
    B1 var byte
    B2 var byte
    B3 VAR BYTE
    GPIO   = 0 ' set port latches low
    TRISIO = 0 ' set ports as outputs
    pause 1000 ' Waste time while serial LCD initiailizes
    For B2 = 0 To 35   ' counter for lookup table
    lookup b2,["A","B","C","D","E","F","G","H","I","J","K","L","M",_
    "N","O","P","Q","R","S","T","U","V","W","X","Y","Z","0","1","2",_
    "3","4","5","6","7","8","9"],B0 ' store each char in b0 1 at a time
    I2CWRITE DPIN,CPIN,$A0,B2,[ b0]  'write to 24C01 eeprom 1 character
    Pause 20
    Next B2       'next character write to eeprom
    DEBUG 254,1   'clear LCD of any leftover data
    loop:
    DEBUG 254,1   'clears away the leftovers each loop
    For B3 = 0 To 35   ' counter for reading 35 characters
    I2CREAD DPIN,CPIN,$A0,b3,[B1]  ' read each character 1 at a time
    pause 500           ' time to see each character on the LCD
    DEBUG 254,2,"CHAR ",B1,"          " ' display the characters 1 at a time
    Next B3                             ' get next character
    I2CREAD DPIN,CPIN,$A0,0,[STR B1\20] ' read a string of  20 characters
    DEBUG 254,2,STR B1\20               ' display those 20 characters
    I2CREAD DPIN,CPIN,$A0,16,[STR B1\16]' get the last 16 characters
    DEBUG 254,$C0,STR B1\16,"    "      ' display those 16 characters
    DEBUG 254,$94,"I2C EEPROM DEMO"     ' display this program's purpose
    DEBUG 254,$D4,"USING ARRAY & STRING"
    PAUSE 1500                          ' time to read the LCD
    'NEXT B3                            ' go do it all again
    Goto loop
    POKECODE @$3FF, $4C  'read your PIC before erasing and put the cal. data here
    Feb 2005
    Kolkata-India
    Default A For-Next Loop
    "A,B,C..." all have an ASCII value. For example "A"=65 so an iteration like this can help
    For I = 0 to 25
    char[I] = I + 65
    Next I
    P.S. PBP Manual has the ascii chart
    Sougata
    Quote Originally Posted by sougata View Post
    For I = 0 to 25
    char[I] = I + 65
    Next I
    As I look at this a year later, I now understand what this snippet does.
    "I realise there are likely easier ways to load the ARRAY . . .Baby Steps"
    It loads the variable CHAR with the Alphabet,<font color = BLUE> A Belated Thanks, Sougata .</font color>
    This response is to point that fact out to anyone new to arrays. Attention Newbies
    Joe,
    Did you know you can do this?
    Dat VAR BYTE
    Alphabet VAR BYTE[26]
        FOR Dat = "A" to "Z"
         Alphabet[Dat-65]=Dat ' load Alphabet array 0-25 with A-Z
         HSEROUT [Alphabet[Dat-65],13,10]
         PAUSE 50
        NEXT Dat
        PAUSE 5000
        GOTO Main
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default Nope !
    Joe,
    Dat VAR BYTE
         PAUSE 50
        NEXT Dat
        PAUSE 5000
        GOTO Main
    Woo Hoo, another tidbit of knowledge! I did not know that.
    Thank You Bruce.
    JS
    Last Post: - 14th June 2016, 08:55
    Last Post: - 7th December 2008, 15:17
  3. Schematic for simple demo
    By iandonahue in forum USB
    Last Post: - 4th March 2008, 16:18
  4. RS232 receive an array (packet)
    Last Post: - 12th February 2008, 06:02
  5. Array to simple Variable converting
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2006, 17:44
