Found my problem after an email from melLabs tech support.
I needed to set all inputs as digital by configuring all pins digital on the 16F690 by setting ANSEL = 0 and ANSELH = 0 in my Register Settings. Once I did this, everything works!
This also answers my question about whether the input from the meter sensor needs to be set as an analog or digital input. Evidently, even though the input is an analog pulse, since it is within the max limits for digital input, having the input pin as digital is OK and precludes having to use code to sample the signal input with the A/D to determine the pulse presence that way. Don't quite understand why a digital input works with an analog signal, but if it works I won't argue with it.![]()
