Buying an Oscilloscope
Results 1 to 12 of 12
    Feb 2008
    Michigan, USA
    Default Saleae Logic
    masosi:
    Just so that I haven't mislead you, the Logic pod only deals with logic (read: 0-5 vdc) levels. It does it very fast, and you can catch spikes, but it is not designed for signal analysis in the traditional way. It only displays ON or OFF levels based on the 5 v logic that it sees.
    For instance, if you want to watch RS232 comm, you have to tap the logic signals before the MAX232 so that you are only working within it's voltage limits. There are warnings about levels over 5 vdc. You could use a voltage divider if needed, but you are treading in thin air if you forget.
    If used within it's design, it solves the problem of seeing what the data pattern is. You set up a decode criteria and it shows what it understands the capture to be. It fills the gap for me so that I didn't have to spend a lot on a new scope.
    Just wanted to be clear.
    Bo
    Apr 2007
    Quote Originally Posted by boroko View Post
    I think i've found something to cover both
    http://www.linkinstruments.com/mso19.htm
    Its a single channel Scope with Logic Analyzer and Pattern Generator. Pretty good price i reckon!
  1. Low-Cost USB Oscilloscope
    By T.Jackson in forum Schematics
    Last Post: - 16th December 2007, 13:10
  2. Analog oscilloscope - what do you think?
    By presario1425 in forum Off Topic
    Last Post: - 29th November 2007, 00:41
  3. oscilloscope
    By therian in forum Off Topic
    Last Post: - 12th March 2007, 13:38
  4. Oscilloscope MHz recomend
    By Normnet in forum Off Topic
    Last Post: - 14th May 2005, 18:58
  5. Buying an LCD Module
    By RossW in forum mel PIC BASIC Pro
    Last Post: - 10th August 2004, 15:37
