general purpose password protected menu
Results 1 to 10 of 10
    Ankara,TURKEY
    Default code and simulation
    Haven't you tried it yet??
    I sure it contain some bugs but I did not confront by any.
    Proteus simulation doesn't work properly I tried it on board it works well
    Electrical & Electronic Engineering
    Undergraduate Student
    May 2008
    Italy
    This simple snipet assume you receive the keypad character serially and that you have a LCD. The password is written on eeprom and lenght can be changed updating Plen constant.
    At start program waits for six characters (in this example six zeroes) and if entries are ok then program proceed to mainloop otherwise print "Access Denied" and return to the PassLoop.
    Eeprom 100,[48,48,48,48,48,48]
    Pass        var byte
    Key         var byte
    Len         var byte
    Char        var byte
    A0          var byte
    Plen        con 6
    T9600       con 2
    Key=0
    len=0
    Lcdout $FE,1
    PassLoop:
    Serin pinx,T9600,Char
    Read 100+len,Pass
    iF pass=Char then
    Key=Key+1
    Key=0
    Lcdout $FE, $80+len "*"
    Len=Len+1
    If Len=Plen+1 then
    If Key=Plen then main
    Lcdout $FE,1,"Access Denied"
    pause 2000
    Lcdout $FE,1
    Len=0
    goto PassLoop
    Al.
    May 2008
    Italy
    In previous code Variable Key was not resetted in case of retrail. Here a shorter corrected code.
    Pass        var byte
    Key         var byte
    Len         var byte
    Char        var byte
    A0          var byte
    Plen        con 6
    T9600       con 2
    IniPass:
    Key=0
    len=0
    Lcdout $FE,1
    PassLoop:
    Read 100+len,Pass
    iF pass=Char then
    Key=Key+1
    Key=0
    Len=Len+1
    If Len=Plen+1 then
    pause 2000
    goto IniPass
    goto PassLoop
    Al.
    Quote Originally Posted by HYETİK View Post
    I haven't tried myself, but for sure I never trust any Sim... Proper ICD setup is more valuable and work on real hardware.
    Here's some other variant of password handling.
    http://www.picbasic.co.uk/forum/showthread.php?t=5695
  1. lcd menu problems
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 19:00
  2. interactive menu with hyperterminal
    By jamied in forum mel PIC BASIC Pro
    Last Post: - 5th January 2009, 11:13
  3. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 07:31
  4. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 07:03
  5. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 01:31
