You can modify it. It is very usefull and simple.
I hope you will like it and wanna use it.
this project doesn't reset password if power is down.
first password is 333333.
zip pass: www.hyetik.co.cc
Electrical & Electronic Engineering
Undergraduate Student
Hi, HYETIK
The little problem is we do not have the password to open th ZIP files ...
Why use one ??? ... it is no need here, as you must show it to everyone !!!
PS : Nice site ... could you add a link to " BabelFish" or an inline translator ... Turkish is not "so easy" for the rest of the world ...
Alain, HYETİK provide the password...
Originally Posted by HYETİK
Password did not work for me either, better to post with code tags like in Steve's Signature.
People are wary of zips from people they do not know anyway.
Please use code tag when you post a code here.
Code:paste your code here
Password worked for me here using ExtractNow software. I've attached a non-password zip here with the code, .HEX and what I feel to be a ISIS schematic.
Let's post the code here too
Code:'**************************************************************** '* Name : UNTITLED.BAS * '* Author : Hasan YETİK TOBB-ETÜ Elektrik-Eletronik Müh. * '* Notice : Copyright (c) 2009 Hasan YETİK * '* : All Rights Reserved * '* Date : 19.02.2009 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** TRISC=0 'LCD BAGLANTILARI TRISB=%00001110 'B PORTU KEYPAD OPTION_REG.7=0 TUS var byte ''''''''''''''''''''''''''''''''''''''''''''lcd TANIMLAMALARI DEFINE OSC 20 DEFINE LCD_DREG PORTC 'LCD data bacakları PortB de bğlı DEFINE LCD_DBIT 4 'LCD data bacakları 4. bitten başlıyor DEFINE LCD_EREG PORTC 'LCD Enable Bacağı PortB de bağlı DEFINE LCD_EBIT 3 'LCD Enable Bacağı 3. bite bağlı DEFINE LCD_RWREG PORTC 'LCD RW Bacağı Portc de bağlı DEFINE LCD_RWBIT 2 'LCD RW Bacağı 2. bite bağlı DEFINE LCD_RSREG PORTC 'LCD RS Bacağı PortB de bağlı DEFINE LCD_RSBIT 1 'LCD RS bacağı 1. Bite bağlı DEFINE LCD_BITS 4 'LCD 4 bit olarak bağlı DEFINE LCD_LINES 4 'LCD 2 sıra olarak çalışıyor. 'DEĞİŞKEN TANIMLAMALARI symbol YATAY_A=PORTB.4 'keypad symbolleri SYMBOL YATAY_B=PORTB.5 SYMBOL YATAY_C=PORTB.6 SYMBOL YATAY_D=PORTB.7 SYMBOL DIKEY_1=PORTB.1 SYMBOL DIKEY_2=PORTB.2 SYMBOL DIKEY_3=PORTB.3 CounterA var byte Match var byte sifre var WORD[6] sifreyeni var WORD[6] sifre2 var WORD[6] DEFAULT VAR WORD[6] KONTROL VAR WORD[6] DURUM VAR byte[1] ILK: READ 9,DURUM pause 100 if durum="a" then goto start else write 1,3 write 2,3 write 3,3 write 4,3 write 5,3 write 6,3 lcdout $FE,1,"SIFRE:333333" lcdout $FE,$C0,"SIFREYI DEGISTIRIN" pause 1000 GOTO START endif Start: match=0 lcdout $FE,1,"SIFREYI GIRIN" for countera = 0 to 5 read 1,sifre2[0] read 2,sifre2[1] read 3,sifre2[2] read 4,sifre2[3] read 5,sifre2[4] read 6,sifre2[5] gosub TUSOKU if tus=80 then sifred if TUS=sifre2[countera] then Match=Match+1 lcdout $FE,($C0+COUNTERA),"*" next countera if match=6 then lcdout $FE,1,"SIFRE DOGRU!" else lcdout $FE,1,"YANLIS SIFRE" match=0 endif PAUSE 1000 goto start sifred: lcdout $FE,1,"ESKI SIFREYI GIRIN" read 1,sifre[0] read 2,sifre[1] read 3,sifre[2] read 4,sifre[3] read 5,sifre[4] read 6,sifre[5] for countera = 0 to 5 gosub TUSOKU if TUS=sifre[countera] then Match=Match+1 lcdout $FE,($C0+COUNTERA),"*" next countera if match=6 then lcdout $FE,1,"SIFRE DOGRU!" goto sifred2 else lcdout $FE,1,"YANLIS SIFRE" match=0 goto sifred endif sifred2: lcdout $FE,1,"YENI SIFRE:" for countera=1 to 6 gosub TUSOKU write countera,tus lcdout $FE,($C0+(COUNTERA-1)),"*" next countera write 9,"a" lcdout $FE,1,"SIFRE DEGISTI" PAUSE 1000 goto start TUSOKU: tus=99 PORTB=254 YATAY_A=0 'YATAY_A=0 IÇIN KONTROL IF DIKEY_1=0 THEN 'DIKEYDEKI TUS1 BASINCA IÇERIGI 0 OLUR BIR KOMUT ATLA TUS=1 WHILE DIKEY_1=0 'BUTON HALA SIFIRMI KONTROL ET WEND ENDIF 'IF ISLEMININ SONU IF DIKEY_2=0 THEN TUS=2 WHILE DIKEY_2=0 WEND ENDIF IF DIKEY_3=0 THEN TUS=3 WHILE DIKEY_3=0 WEND ENDIF HIGH YATAY_A YATAY_B=0 IF DIKEY_1=0 THEN TUS=4 WHILE DIKEY_1=0 WEND ENDIF IF DIKEY_2=0 THEN TUS=5 WHILE DIKEY_2=0 WEND ENDIF IF DIKEY_3=0 THEN TUS=6 WHILE DIKEY_3=0 WEND ENDIF HIGH YATAY_B YATAY_C=0 IF DIKEY_1=0 THEN TUS=7 WHILE DIKEY_1=0 WEND ENDIF IF DIKEY_2=0 THEN TUS=8 WHILE DIKEY_2=0 WEND ENDIF IF DIKEY_3=0 THEN TUS=9 WHILE DIKEY_3=0 WEND ENDIF HIGH YATAY_C YATAY_D=0 IF DIKEY_1=0 THEN tus=80 WHILE DIKEY_1=0 WEND ENDIF IF DIKEY_2=0 THEN tus=0 WHILE DIKEY_2=0 WEND ENDIF IF DIKEY_3=0 THEN tus=0 WHILE DIKEY_3=0 WEND ENDIF HIGH YATAY_D IF TUS=99 THEN TUSOKU RETURN
Haven't you tried it yet??
I sure it contain some bugs but I did not confront by any.
Proteus simulation doesn't work properly I tried it on board it works well![]()
This simple snipet assume you receive the keypad character serially and that you have a LCD. The password is written on eeprom and lenght can be changed updating Plen constant.
At start program waits for six characters (in this example six zeroes) and if entries are ok then program proceed to mainloop otherwise print "Access Denied" and return to the PassLoop.
Code:Eeprom 100,[48,48,48,48,48,48] Pass var byte Key var byte Len var byte Char var byte A0 var byte Plen con 6 T9600 con 2 Key=0 len=0 Lcdout $FE,1 PassLoop: Serin pinx,T9600,Char Read 100+len,Pass iF pass=Char then Key=Key+1 else Key=0 endif Lcdout $FE, $80+len "*" Len=Len+1 If Len=Plen+1 then If Key=Plen then main else Lcdout $FE,1,"Access Denied" pause 2000 Lcdout $FE,1 Len=0 endif endif goto PassLoop Main:
Al.
In previous code Variable Key was not resetted in case of retrail. Here a shorter corrected code.
Al.Code:Eeprom 100,[48,48,48,48,48,48] Pass var byte Key var byte Len var byte Char var byte A0 var byte Plen con 6 T9600 con 2 IniPass: Key=0 len=0 Lcdout $FE,1 PassLoop: Serin pinx,T9600,Char Read 100+len,Pass iF pass=Char then Key=Key+1 else Key=0 endif Lcdout $FE, $80+len "*" Len=Len+1 If Len=Plen+1 then If Key=Plen then main else Lcdout $FE,1,"Access Denied" pause 2000 goto IniPass endif endif goto PassLoop Main:
I haven't tried myself, but for sure I never trust any Sim... Proper ICD setup is more valuable and work on real hardware.
Here's some other variant of password handling.
http://www.picbasic.co.uk/forum/showthread.php?t=5695
