Transistor selection, PWM fan control
Results 1 to 6 of 6
    Nov 2008
    I knew there was a formula, I kept getting stuff about air conditioners and science projects when I searched.
    Yeah, It reads a coolant temp. sensor and controls the radiator fan speed. This is my first time using PWM, got started yesterday on a breadboard with a 80mm PC fan. 4 kHz was noisy, 20kHz is working real well. I’m more excited about PWM than I should be, I’ve been connecting other things to the circuit to see how they respond.
    Ordered some MOSFETs , looks like they will be useful for all sorts of mischief.
    Thanks for you help.
    Quote Originally Posted by 124C41 View Post
    I can't think of any vehicle application that actually uses full PWM to control a radiator cooling fan. 2, maybe 3 or even 4 settings, maybe...but not a full range of 0% to 100% duty cycle controller of a fan motor.
    Sounds like some serious overkill...
  1. Proportional fan control. I suck at math!
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 4th January 2010, 00:10
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. CCP vs power control PWM
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 4th September 2008, 04:09
  4. Replies: 9
    Last Post: - 30th August 2005, 07:33
  5. MOSFET control using PWM & 16C711?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 03:24
