Hserin
Results 1 to 12 of 12
Thread: Hserin
    Feb 2005
    GREECE
    Question Send hex to PIC-->DS160
    Hello to everybody,
    I have ALSO a problem with HSERIN(?).
    My setup is CPU 16F627A internal OSC 4Mhz.I want to send via a termial(hyper or similar) a byte to pic.
    The PIC reads the byte and it sends to the DS1620 Digital Thermometer and Thermostat.That is not working......
    FOR EXAMPLE if i send via the termial the hex A1 (this is the InChar) I should have take an answer to the terminal with the stored value of high temperature limit.The DS1620 is working with the PIC.
    BUT I CAN NOT FIND THE MISTAKE
    HERE IS MY FULL CODE
    include "modedefs.bas"
    @ DEVICE pic16F627A, INTRC_OSC_NOCLKOUT ' system clock options
    @ DEVICE pic16F627A, WDT_ON ' watchdog timer
    @ DEVICE pic16F627A, PWRT_ON ' power-on timer
    @ DEVICE pic16F627A, MCLR_OFF ' master clear options (internal)
    @ DEVICE pic16F627A, BOD_OFF ' brown-out detect
    @ DEVICE pic16F627A, LVP_OFF ' low-voltage programming
    @ DEVICE pic16F627A, CPD_OFF ' data memory code Protect
    @ DEVICE pic16F627A, PROTECT_OFF ' program code protection
    CMCON = 7 'Turn off comparators
    VRCON = 0
    INTCON = 0 ' Disable interrupts
    ' DEFINE VARIABLES FOR SERIAL TO PC 2400 8-N-1
    ;DEFINE NO_CLRWDT 1
    DEFINE HSER_CLROERR 1 'Automatically clear over-run errors
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 2400
    DEFINE HSER_SPBRG 25
    ;DEFINE HSER_CLROERR 1
    ;DEFINE HSER_RCSTA 90H
    ;DEFINE HSER_TXSTA 20H
    ;DEFINE HSER_BAUD 2400
    ;DEFINE HSER_SPBRG 25
    ' DS1620 control pins
    RST var PORTA.4 ' Reset pin
    DQ var PORTA.2 ' Data pin
    CLK var PORTA.3 ' Clock pin
    INPUT PORTA.3
    INPUT PORTA.4
    ' Allocate variables
    temp var word ' Storage for temperature
    InChar VAR byte
    RCIF VAR PIR1.5
    Low RST ' Reset the device
    START:
    While RCIF = 1
    hserin 100,start,[InChar]
    mainloop:
    RST = 1 ' Enable device
    Shiftout DQ, CLK, LSBFIRST, [$ee];Shiftout DQ, CLK, LSBFIRST, [$ee] ' Start conversion
    RST = 0
    Pause 1000 ' Wait 1 second for conversion to complete
    RST = 1
    Shiftout DQ, CLK, MSBFIRST, [InChar] ' Send read command
    HSERout [InChar]
    Shiftin DQ, CLK, LSBPRE, [temp\9] ' Read 9 bit temperature
    RST = 0
    ' Display the decimal temperature
    hserout [" Temp = ",dec (temp >> 1), ".", dec (temp.0 * 5)," oC",13]
    Wend
    Goto START ' Do it forever
    PLEASE I need your advice
    Nikos
    Quote Originally Posted by ngeronikolos View Post
    Use a 4Mhz crystal or resonator instead of the internal 4Mhz.
    HERSIN/HSEROUT are clock sensitive. The DS1620...not so much...
    Feb 2005
    GREECE
    I will try to add an external crystal BUT i do not think that this is the brpblem!!!!!!!!!!The echo sample code for HERSIN/HSEROUT is working...
    Something else happend.When It reads the byte and trying to send to DS1620
    (Shiftout).
    (Shiftout).
    Maybe you need to make the variable a number of some kind?
    From the manual...
    Modifier Operation
    {I}{S}BIN{1..16} Send binary digits
    {I}{S}DEC{1..5} Send decimal digits
    {I}{S}HEX{1..4} Send hexadecimal digits
    REP c\n Send character c repeated n times
    STR ArrayVar{\n} Send string of n characters
    Feb 2005
    GREECE
    My variable is the InChar (look the code) and I set it as a byte.
    The possible value could be $a1 or $a2 or $aa.
    When I type that value via the terminal I have it back (hserout) but I do not have correct answer from the DS1620.
    The strange thing is that I send
    $a1
    and I receive back
    a
    1
    hserin 100,start,[WAIT($), HEX InChar]
    Shiftout DQ, CLK, MSBFIRST, ["$",HEX InChar]
    MAYBE????
    Do you have a Pull-Up resistor on PORTA.4 (RST)?
    It's an Open Collector output, so it can't go HIGH on it's own.
  1. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  2. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 06:13
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
