Hserin
Results 1 to 7 of 7
Thread: Hserin
    egberttheone's Avatar
    egberttheone Guest
    Cool Hserin
    1ste post!
    hello all. I seem to have a problem with serial receive.
    this is the code that I use for sending the data, I already used +10 because it seems that it doesn't do any thing when sending a zero
    HSerout [day + 10]
    HSerout [month + 10]
    HSerout [year + 10]
    HSerout [hour + 10]
    HSerout [minute + 10]
    HSerout [second + 10]
    and this is the code that I use for receiving
    HSerin 3000,TimeOut, [CurrendDate(0)]
    HSerin 100,TimeOut, [CurrendDate(1)]
    HSerin 100,TimeOut, [CurrendDate(2)] '?
    HSerin 100,TimeOut, [CurrendTime(0)] '?
    HSerin 100,TimeOut, [CurrendTime(1)]
    HSerin 100,TimeOut, [CurrendTime(2)]
    the problem is that if I send "10,11,12,13,14,15" I'll receive "10,11,13,13,14,15" any explanation for this? I tryed every thing
    Welcome to the forum.
    Here's a few suggestions you may find useful for synchronizing serial communications, and shrinking your code size in the process.
    1. Try using the STR modifier with HSEROUT/HSERIN to send/receive strings of data rather than using multiple HSEROUT/HSERIN lines to send/receive.
    2. Use some type of synchronization character to lock onto the first byte or "synch up" with the 1st character.
    Note: This is just a simple example. Change whatever you need to like the TimeOut value, label, array size, baud rate, etc,,.
    DEFINE  OSC 20
    DEFINE  HSER_BAUD 9600  ' Use 9600 baud
    DEFINE  HSER_CLROERR 1  ' Auto clear over-run errors
    RCSTA = $90 ' SPEN & CREN = 1
    TXSTA = $24  ' TXEN & BRGH = 1
    TimeDate VAR BYTE[6]
    Main
        HSERIN 5000,TimeOut,[WAIT("A"),STR TimeDate\6]
        HSEROUT ["Rcvd string: ", STR TimeDate\6,13,10]
        GOTO Main
    TimeOut:
        HSEROUT ["Nada",13,10]
        GOTO Main
    Use a terminal program to send A369621 to your PIC. If all's well, you'll see;
    Rcvd string: 369621
    If all's not well, you'll see;
    Nada
    This will save you a TON of code space, and it's much easier to manage.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    egberttheone Guest
    well it seems to work now but i already got a other problem:
    if i try to put a value of a variable into the array, then the interrupt routine(timer) stops working!
    TimeDate(1) = DayREC
    TimeDate(2) = MonthREC
    TimeDate(3) = yearREC
    TimeDate(4) = HourREC
    TimeDate(5) = MinuteREC
    TimeDate(6) = SecondREC
    i don't understand why it does the variables are bove byte's accept that the other varaible is in a array
    For array you must use bracket instead of parenthesis but it's maybe a typing error...
    if not, can you post your whole code ?
    EShatara's Avatar
    EShatara Guest
    Question Hserin Syntax
    What is the "5000" used for in the following statement
    Main
    GOTO Main
    Looking all through the PBP manual doesn't shed light on this question.
    thanks...chris
    EShatara's Avatar
    EShatara Guest
    Lightbulb Figured it out?
    After rereading the discription of the HERIN command, it would appear that the syntax:
    Herin 5000, Timeout, [.....]
    indicates that parity is turned on and that the parity error routine is at address "5000".
    Is this corrrect?
    /chris
    egberttheone Guest
    Thx for your help all, i changed some things and it works !
  1. Hserin with Instant Interrupts.
    By ronjodu in forum Serial
    Last Post: - 30th December 2014, 21:17
  2. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  3. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 06:13
  4. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  5. 16F877a Interupt driven Hserin
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2006, 01:38
