OSCTUNE and 12F683
Results 1 to 4 of 4
    Omaha, Nebraska USA
    If you set INTOSC instead of INTOSCIO, you should get Fosc/4 on the OSC2 pin, which in your case, you should get 32.8khz. Hope you've got a tight freq counter or a good o'scope!
    Thanks for the suggestions. I don't know why I can't find what I need in the 12F683 data sheet but (as I'm sure you've noticed), Microchip's data sheets aren't always as user-friendly as they perhaps could be.
    And I've got both a good (but old) frequency counter (Hewlett-Packard 5300B that last calibrated at 200 ppb) and of course I've got a scope . . . three, right now. (Although my venerable Philips PM3266 is a dinosaur.)
    Interestingly, I intend to use that 32.8 kHz coming out. Although I can probably make do with anything between 32 and 34 kHz, so the tuning may not be as fussy as I am.
    Again, thanks.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Quote Originally Posted by RussMartin View Post
    It might be more accurate to run the PIC as fast as you can (8Mhz on the internal) and write a blinky LED to give you ~32khz on a single pin.
    main: led (whatever pin) = 1
    pauseus 29
    led = 0
    pauseus 28
    1 cycle for each LED=x statement, 2 cycles for goto, 57 cycles for each pause = 61 cycles total.
    8Mhz / 4 = 2 MIPS / 61 cycles = 32,768 Hz.
    Then, between changing the pauseus values, and tweaking OSCTUNE, you should get dead-on exactly what you really want.
